66 f-100 frontend
Old Nov 14, 2000 | 09:49 PM
twr's Avatar
twr
66 f-100 frontend
I was thinking about changing my whole front end
and from what I can gather anything ut to a 79
will work. I would also like to put power
steering on this at the same time. can I take
the whole steering colume and pump etc. from the
same donor truck? I was also wondering if any
year truck was better or worse for this switch?
thanks
Old Nov 14, 2000 | 10:30 PM
timpage's Avatar
timpage
66 f-100 frontend
You are correct in the years, 1973 throuhgh1979 will work for a power disc brake coversion. And yes, from what I have been told power steering can be added from the same donor truck. The column also is interchangeable, and the other powersteering hardware will work best if the donor truck has the same class of engine as the 1966 truck you have.
Old Nov 14, 2000 | 11:29 PM
jowilker's Avatar
jowilker
66 f-100 frontend
Trever, your truck came with a 352 if it is V8, so find a donor 75-76 with a 360 and buy it. Get the parts that you need fo power steering and brakes upgrade.
John
jowilker
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old Nov 15, 2000 | 03:15 PM
scotty's Avatar
scotty
66 f-100 frontend
I just did the same thing on my'67F100, except
I didn't use power disc brakes, just the discs
and my right leg for power. I pulled the I-beams,
radius arms etc. at a yard got all that and the
steering column and gear for $101.00. spent another $70 on new bushings for the I-beams and
radius arms. Hope you have nice weather, it's getting cold here in MN.
scotty
'67F100
Old Nov 15, 2000 | 07:31 PM
twr's Avatar
twr
66 f-100 frontend
thanks for the help there are lots of 70 fords
here I should have no problem finding a donor
truck. As for cold I live Nova Scotia Canada
so i have been throwing all the wifes stuff
out of my garage to make room for the change
before I freeze.
Old Nov 15, 2000 | 08:01 PM
cams69's Avatar
cams69
66 f-100 frontend
you're right scotty it is getting cold here is MN!!!
Brent
1969 F100 2wd
Old Nov 15, 2000 | 11:06 PM
1966ford's Avatar
1966ford
66 f-100 frontend
Where in MN are you guys from? I am in Fergus Falls.
Garrett
[link:www.1966ford.com|1966ford.com]
Old Nov 16, 2000 | 05:05 PM
scotty's Avatar
scotty
66 f-100 frontend
I'm in Mpls. where you at Brent?
Scotty
'67F100
Old Nov 16, 2000 | 05:52 PM
cams69's Avatar
cams69
66 f-100 frontend
Rachel Moody
15
Jan 16, 2017 11:51 AM
Marty1965
1997 - 2003 F150
Sep 8, 2016 05:16 PM
lngroller
Jun 1, 2016 05:57 AM
brseidel
Oct 15, 2010 06:13 PM
debestuss
Dec 11, 2005 10:19 PM
