windsheild replacment
Old Sep 28, 2006 | 04:12 AM
dmacfordshot04's Avatar
dmacfordshot04
my 86 f150 needs a windsheild.is this a tough job installing a new one?never did it before.thanks
Old Sep 28, 2006 | 05:10 AM
fellro86's Avatar
fellro86
It can be, getting it cut out can be a challenge, and then getting it to reseal has been troublesome...
Old Sep 28, 2006 | 07:00 AM
dmacfordshot04
its allready cracked,so not worried about removal.im more concerned about putting new in straight the first try.heard once windshield touches glue seal thats it ,shes stuck.
Old Sep 28, 2006 | 07:34 AM
Sport45's Avatar
Sport45
It's a real common windshield. Call your local auto glass shop for an estimate. You might be surprised. I just had one put in my '83 for less than $150. New glass, lifetime warranty against leaks, and I didn't have to mess with the chrome trim or anything.
Old Sep 28, 2006 | 07:35 AM
fellro86's Avatar
fellro86
Well, getting it out still is an issue, the factory sel is hard to get cut sometimes. When I put mine in, I didn't get the seal, just used windsheild sealant, basically silicone, and I'm not real pleased about it, probably will end up having to do it again. Cost 85 to do it myself, I agree, check out the glass shops and see. (bought windsheild used, they broke 3 before getting one out...)
Old Sep 28, 2006 | 08:34 AM
Sycostang67's Avatar
Sycostang67
There's too much to go wrong for me to try something like that myself. I paid $180 1.5 years ago to get one put in my F-250. I tried one of those DIY chip repair kits one time, and turned the chip into a 12" crack. I don't play with glass anymore.
Old Sep 28, 2006 | 10:11 PM
Bdox's Avatar
Bdox
Had mine done, $156. In and out in very little time.
I've done it before but it took me ten times as long, plus the risk of leaks and breakage. Just not worth it.
Old Sep 28, 2006 | 11:16 PM
locknkey's Avatar
locknkey
To do it right , it will take a min of 3 people, useing music wire to cut the seal, remove all the excess old material, clean up, reseal and tack the window in then replace the brackets along with the window frame trim...I watched them do it (Body/Glass Repair Shop) and it was no easy task for one person to do by themselves correctly and NOT break or crack it and get it to not leak. It does have to cure 24 hours before water is supposed to be introduced to it...good luck if you try it.
My windshield cost 215.00 but I was watching them too....
Old Sep 30, 2006 | 10:59 AM
diggerrigger's Avatar
diggerrigger
windshield replacement
How do you remove the trim around the windshield?
I believe a a trickle of rainwater from under my dash may be caused by a windshield leak. My windshield was professionally installed in '95. However, I would like to visually inspect the perimeter seal that is concealed by the trim. I would be looking for a failed seal or a possible rust through.
Old Sep 30, 2006 | 11:11 AM
fellro86's Avatar
fellro86
You need a tool to get back into the clip that holds the trim, it looks like an arrow, the points get behind the clip and pull it out so the trim can come up.
Old Sep 30, 2006 | 11:35 AM
diggerrigger
Thanks, Im headed for the parts store to get one now.
Old Oct 1, 2006 | 05:59 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Make sure to check the cab corners.
The windshield and seal may not be leaking itself.
Look around where the roof of the cab connects to the pillar, the automotive caulking may have cracked and is allowing moisture and water through the "join". A very comon problem for the 1980 to 96 f-series.
A glass shop can fix this problem as well, and it's easier to ask them to inspect the "Joins" and have them filled with auto claulk, if needed with the windshield out of the truck.
Hope this Helps,
cammo
Dec 3, 2014 07:06 PM
oldmerc
Apr 18, 2013 10:46 AM
chaser1602
Jan 17, 2011 11:08 PM
John Caro
Oct 26, 2009 04:59 PM
vinlin95
Dec 7, 2007 12:02 PM
