1st tank of bio
on
1st tank of bio
finally found bio here the in white mountains of nh.its 2.69 a gal. we seem to be last part of the country to get good stuff.
what a different this stuff made on the rattling sound the 7.3's make at idol. its a lot quitter and smoother.its only my 1st tank with only 155 miles gone through it. cant wait to see how it is after a couple tanks worth.im interested in how the fuel mileage will be. I'm getting b20 right now. what is the different compared to b100?
thanks in advance,
Ron
thanks in advance,
Ron
You won't notice any difference between b20 and b100, other than the fact that the gel point is noticiably higher with b100.
Mileage normally doesn't change much when you run bio compared to straight #2. However, if you have a lot of gunk in your tank, it will show up in the fuel filter. Be ready to change that out sooner than normal until the tank is clean.
I had commercial B20 dumped in to an almost empty tank. Didn't change my mileage. However, I have had fuel that consistantly lowered my mileage which is why I prefere the splash mix method. Every time I filled up with their fuel, mileage and power dropped. Every time I went with my usual source, mileage and power increased. Did that a few times to verify before not going back to that source of fuel. That way I can control the diesel portion of the fuel to keep things as consistant as I can. Which is why I said that B40 definately dropped my mileage after a little testing.
I am interested in how Aklim lost milage. Every testing and personal use with bio for me has resulted improvement. Everyone I know has a quiter engine, cleaner honey colored oil, more power and so on. This is a result of the super o2 content. You should even feel up to 4 centane higher than reg dino. Skip over to the bio section and take a read.
Maybe I am not getting as good biodiesel as some others. Not sure. I know that in town I can get a fuel from a certain place and power and mileage will consistantly drop and hence I avoid that place.
It didn't make sense to me till I read up on the biodiesel site and found that B100 was less energetic than D2. Seems to me like it would be in their best interests to state it has as much BTU as D2 and I can't see any reason why they would say it wasn't unless they are being truthful. Kinda like a Ford dealership owner saying that Chevy has a better product.
http://www.biodiesel.org/pdf_files/fuelfactsheets/BTU_Content_Final_Oct2005.pdf
According to the wife, B20 gives it a more refined sound. My mileage on B20 didn't make a difference one way or the other. Sometimes I picked up a tenth and sometimes lost a couple of tenths. Too ambigious to state that there is a loss or gain. Never checked as far as the oil went. Maybe someday I will. Starting seems to not make a difference at all.
as for checked millage i haven't cheked to see if there is a difference but as a person who is real good with the throttle i notice a power drop with b20 in my tank, it seems to take more throttle to do the same thing as d2. the only b20 i can get is red hawk premium b20. i use it everynow and them for the lube qualities but it is 40 miles away so i only use it when i am in the area
Me personally, I saw almost no difference in mileage when running Bio compared to #2. I've also run everything from B2 to B100, most of the time staying with B20. I prefer to run bio over #2 simply because of the solvent effect on my fuel system, quieter injectors, and better smelling exhaust. Unfortunately where I live now, it's too far of a drive to get it.
As to the solvent effect, I would probably run a tank thru say every year or so just to keep things clean. My truck has 70K and when I did the hutch and harpoon mod I noticed it was clean as a whistle. Except for the filters, that is. Those were filthy and crudded up. Well, no more on that. All filters removed and plumbed into a 4 micron filter.
Well I cant argue with others about their truck and how it runs so here is what I know.
Higher cetane rating, burns consistantly down the cylinder therfore increasing power and reducing the normal diesel sound.
Possibilities---California facility was recently found to be producing sub-par biodiesel. Test showed incomplete reactions, soap and glycering contaminations as well as water.
Most of us producing our own or have used homemade have a product that is far superior to mass produced factories that have no experience in the fine art. For anyone that is interested here is the formula as described to me by the one and only Fabman on our bio forum. I have made several trips and phone calls to this very knowledgeable individual who is hellbend on GIVING this information to all farmers, co-ops and anyone else willing to go to the hardware store and buy the supplies.
Formula goes as followed---for every 25 gallons of veggie oil
25gal of veggie heated to 150 degrees
seperate mix
5 gal of methanol
3lbs of Kaoh aka Potassium hydroxide
mix two for 1/2 to 1 hour...do not breath do not touch and its as flamable as gasoline
add mixture to oil and mix for 1 hour then pull to holding tank and let settle
That is the basics, were using vacuum motors from freezers, pumps from http://www.harborfreight.com/cpi/cta...temnumber=1479 and barrels and totes. My original calculations were 74 cents a gallon but firerooster says that methanol prices have gone up.
seperate mix
5 gal of methanol
KennedyFord: Possibilities---California facility was recently found to be producing sub-par biodiesel. Test showed incomplete reactions, soap and glycering contaminations as well as water.
Some observations I have made Regarding Bio.
I have been using bio for about 2 years now mostly B20 to B10 and I see the discussions about mileage either going up down or staying the same.
B100 Flows very nice little foam but B10 and B20 Actually from my observation flow a little more foamy, Now when I do my Mileage I know I am dead on right why? Well I fill it to the rim so to say, Yes I actually am the guy sitting there for the extra 3-4 mins at the pump slowly filling my tank to very top.
I can get another 3-4 gallons into my tank if I fill it slow my advertised tank size is 18 I have gotten 21.5 gallons in there when I was almost dead empty.
Ok what does this have to do with mileage ok if the foaming while fueling your tank does not allow you to get a accurate reading of how much fuel you put in then your data is flawed.
Lets say Monday truck full with Reg diesel then 300 miles later you fill up with the foamy Bio diesel lets say it takes 18 gallons to fill it up great the mileage on the regular diesel now is 16.6 MPG. Now with the bio in the tank you get to 260 on the odometer and its time to fill up you fill up with say reg again now because your like WTH I get 300 to a tank, So now its 21 gallons of Reg diesel later and now the mileage drops to 12.42. Seeing this I would stop using the stuff also.
I had a friend tell me that after running bio that his truck went way down in mileage I mean way down, then after convincing him to do a comparison by filling all the way to the top he saw the light truck ran quieter and he did notice a small mileage increase.
So before you going tearing down the motor or changing filters and oil and all just be sure your data is as accurate as can be.
I know a very long post but I just got to rambling I guess.
