How to remove front driver side panel ? and few Questions (remote starter install)
I just ordered Code Alarm 530 remote starter w/ moudle box for my F150 2004from KCautosounds, Travis. It will come with pre-wires and instruction etc.
Man,i m exiciting hehe..
I m pretty okay with wires ...I installed some big lights "KC", HID lights etc so i guess its same idea..
Now i need to colletct some good tips, advice etc..
How do I remove front panel (driver) side with careful? is it snap on? or is there any screw bolt hide somewhere?
HOw do i find igition wires ? where is it located at ?
Any other tips??
Thanks!
YOMAN!
Any other tips??
Thanks!
YOMAN!
O.K. there are 2 7mm screws at the bottom of that trim panel then it has 2 clips at the top. Pull it out straight. Under that there is a metal reinforcement panel that has 4 screws. To get to the ignition switch wiring there is 1 screw that holds the bottom cover on, it also snaps to the top cover. The bottom cover slides out fairly easily and should give you room to get the the ignition switch wiring.
