ok well as some of you know i had recentley put on clear rof lights and turn signals and a smoked 3rd brake light and a line of fire railgate light...well the tailgate light is coming off...i dont like the look of it at all and i cant stand it anymore...i have come to really like the look of the marker lights like my dads dually has. and ive noticed that the truck already has pre drilled oles where it would go....my question is where can i fine one that looks like that and that fits in those factory holes that is LED...if not LED i wouldnt mind the OEM light bar...where can i get those? i know i can get it through the dealership but is there any where else?
if you don't want the bulky look of that link listed above (or factory styling), check out NAPA for some slim LED's like the Truck-Lite model 35's!! i didn't want the mounting bar on there so i used the factory holes as guides to drill and mount my running lights! then i added 2 lights on either side for the turn/brake LED's
LED's durring test fit process. mput masking tape on to mark and drill holes.
tripple light's lit w/ running lights
all lights lit! outer pair of lights lite when brakes/turn signals applied.
about an hour of marking, measuring, and drilling holes.........30min of wiring and BAM there ya go! hope it helps you ideas!
that looks great but i dont want to drill anymore holes...i already drilled 5 from the line of fire and had to patch them up...i just want to use the oem holes
I found mine at Tractor Supply Company - fit the original holes excellent. Since my truck is black, I sprayed the stainless black to hid it a bit. The LEDs are awesome and brighter than my brake lights. I think it was around 20 bucks.
napa part no. for lite bar is 15745r lite kit & 93945 is wiring harnes is ford direct replacement also they make it in yellow #15745y and cab lite kit# is 25062y also factory fit & look.
The stock dually ID bar is the truck-lite model 15 ID bar. You can swap the model 15 lights on it directly out for the model 15 LED versions if you want to keep the LED look. The light bar will bolt right into the pre-existing holes, and you can wire it up to the license plate wiring.
Or you could buy a dually and avoid all the work of the install.
