01 overdrive switch on gear selector
#32
overdrive switch
I have a 02 F250 4X4 PowerStroke,the O/D lite is flashing and does not want to shift out of 1st.Could these two things possibly go together? I still did not have a chance to check the codes.
#33
#34
#35
Could this also cause the truck to stall?
#36
I figured out how to take the dash out but my column shifter would'nt shift out of park & it sounded like some thing broke on my shifter column, It on a 1992 E150 w/4od auto trans......Ordered a new cable but it feels like something is jammed....What the hell is it!!!
Not usually I don't think. It's not impossible, but if it's stalling, it's usually fuel/vacuum/IAS related.
#37
#38
Found out problem, R & S Strauss actually sold me the right part, the shaft itself which contains an inner shaft & 2 blades on each end bolted on the steering column, etc,etc.... w/the bottom end is attached to the actual cable to da trans by 2 bolts...Well da outer shaft (the old one) cracked in half...Which is miracle Strauss Auto had the actual part (Usually acquired by only Ford Dealership Parts Dept) Never had a shifter break on me like that B4 ,or ever!!!!......Nuff Said
#39
#40
#41
Overdrive switch
Thanks Mark !
I would swear in my old 95 model F350, pushing that button worked at a lot slower speed. I drive in the north Georgia mountains a lot, and turned off overdrive rather than using the brakes going downhill.
Did notice when I was coming home last night... just hit the button to check....and it down shifted.... first time it worked with this truck. LOL I suspect I was over 50mph... even though that road has a 45 mph limit.<G>
Going to TN for the next few days... glad to know what I was doing wrong.
Bill
2001, F250,4x4, 7.3, 260,000 miles
1995,F350, Dually, 7.3, 375,000 miles...wish I had kept my old baby...
Bill
#42
Overdrive shifter not working correctly ?
Mark...or whomever...
I tried above 50 mph...and it appears when I pushed switch, the tranny was placed in neutral... ? rpm's went to 800 or so....
After mulling this over... I did it again. Same thing... went to neutral, I even raced the engine.
I quit messing with it after that, since I was 200 miles from home ! <s>
Any thoughts? Sounds like something on other end is not working right? That the switch is working ?
Last edited by MoBill122; 11-23-2009 at 08:54 AM. Reason: Why are there lines striking out my note????
#43
