F100 Axle seal leak
Old 06-06-2001, 06:17 AM
jowilker's Avatar
jowilker
jowilker is offline
F100 Axle seal leak
Guys I have replaced a couple of axle seals on one side of my 66 and it continues to leak. Everything seems to be clean, but I may be missing something.
Any suggestions on stopping this problem, brake shoes get expensive after a while.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
Old 06-06-2001, 07:07 AM
Nathan's Avatar
Nathan
Nathan is offline
F100 Axle seal leak
John, have you checked to see if the axle housing vent is clear and breathing well? Most axle seal leaks can be fixed by simply unclogging the vent.
Nathan
Old 06-06-2001, 02:03 PM
jowilker's Avatar
jowilker
jowilker is offline
F100 Axle seal leak
Thanks Nathan , I'll give it a look see.
John
jowilker
66F100s Rule
Old 06-06-2001, 07:27 PM
Nathan's Avatar
Nathan
Nathan is offline
F100 Axle seal leak
Let me know what you find, buddy. E me if you like.
Nathan
Old 06-06-2001, 08:41 PM
jowilker's Avatar
jowilker
jowilker is offline
F100 Axle seal leak
Nathan, U da MAN!! I looked at the hose carefully and it seemed to be OK, but I says to mysself, self cut that hose off at the metal and take a look, you can always stick it right back on. Man 35 years of crud stopped up as thight as a banjo string. I finally had to take the smallest drill bit in my case and twist it through (by hand)to make a hole again.
I went back to the brake drum, sprayed everything down with carb cleaner, including the new shoes, and put it together again, hoping to stop that grabbing.
I'll take it out tomorrow on a test run, it was raining tonight, and there wasn't any big reason to take it out to see how much dirt I could add to it.
Come to Carlisle and have a cold one on me.
John
jowilker
66F100s Rule
Old 06-06-2001, 09:40 PM
64fordguy's Avatar
64fordguy
64fordguy is offline
F100 Axle seal leak
Old 06-06-2001, 09:43 PM
Nathan's Avatar
Nathan
Nathan is offline
F100 Axle seal leak
>cold one on me.
>John
>66F100s Rule
>rusting away.
If I could, I would PAL!! Aint it great when its that simpleOoo
Nathan
jowilker
North Carolina Chapter
20
06-28-2002 10:43 AM
jowilker
Events & Happenings
02-06-2002 02:41 PM
jowilker
21
06-06-2001 05:19 AM
jowilker
04-08-2001 08:08 PM
jowilker
04-07-2001 12:17 AM
Quick Reply: F100 Axle seal leak
