MBRP 3.5" Downpipe Install
Hello everyone,
Having some problems installing a 3.5" downpipe to my stock straight-piped exhaust. My truck is a early '99 F350 CC LB SRW 6sp manual trans. When I bought the truck I noticed the catalytic converter had been removed for a straight pipe with a ford serial number stamped on it. My problem is: It appears the stock downpipe is 3" from the Turbo to where the catalytic converter would've been. There is a collector that appears to go from 3" to 3.5". My MBRP 3.5" DP is much shorter than the stock DP and seems to end about 12" on the turbo side from the collector.
I noticed a few on this forumn are running a 3.5" DP with their stock exhuast. What have you all done to remedy this? Any advice would be much appreciated. Thanks!
Chris
Early '99 F350 XLT CC LB SRW 6sp
Mods: Straight pipe, CCV, Ford AIS w/Zoodad, Oilguard bypass, SS Hpx, Autolite Pyro & boost
Future Mods: Dp tune & ITP regulated return
Chris
Originally Posted by powrstrkn'
You should be able to find a piece of 3.5" i.d. pipe and slip it over your dp in order to make up the 12 inch difference remove the 3-3.5 adapter and just clamp it all together or if you have access to a weld smoke em together
Originally Posted by Tenn01PSD350
I canot believe that MBRB makes a DP that is shorter or will not fit with what you have under there. Anybody else? I know many folks have gone that route. Not me though.
Chris
Early '99 F350 CC LB SRW 6sp
Mods: CCV, SS hpx, Ford AIS w/Zoodad, straight-pipe stock exhaust, Oil Guard bypass, Grill Gutter Mod
Future: DP tune, ITP regulated return
