Buying and Selling Thread part 1
I'll start thinds off with a set of 9" Precision 3.30:1 gear set. I bought them from ebay and never installed them. I ended up with a set of 3.0:1.
They came out of a Nascar for quilifying laps so they only have like 50 miles on them.
They look new and are in the foam shipping package.
If you would like pictures I can provide them.
jd
jd
i have a ford FT thick walled block great for a hot 390 build up , extra webbing mirror 105 block with caps. 100.00
WANTED: '73, '74 or '75 F-250 2 wheel drive - ANY CONDITION
I'm looking for a currently registered (or not too far out) or non-op'd F-250 two wheel drive -- '73, '74 or '75.
ANY CONDITION – Frame only - Wrecked - Blown engine - No engine - Just plain old! If it can be registered, I will come and pick it up.
I need the registration, the frame and the VIN tag off of the driver's door. I'd like to do a frame-up restore on my truck and want a pre-smog frame to work from.
Please message me with ANY information. I'm in the Central Valley (Visalia).
Thanks for your help guys.
Jim
Jim
on
Looking for a 1980 or 1981 F-series Explorer Hood Ornament, to replace a rock cracked one on my truck. I can use one off of a 1976 to 1979 ford truck, (color black) but would have to take it apart because altough the ornament is the same the mount of the ornament is different.
on
I'm looking for a set of cheap, used headers for a 67-72 F250 with an FE (2wd, std. trans)
I know I can buy new ones for a little over a hundred bucks, but I'm cheap and this engine won't be in the truck long, I just to get some headers on it while it is in there.
I like doing trades as well, have a lot of 302 stuff...as well as a '72 F250 I guess I'll be parting out.
Thanks!
Thanks!
Looking for a replacement 16.5 x 12 8 lug rim
The saga of my son's truck continues. Turns out he has a cracked rim. It appears to have been repaired before, but the crack is of a type I would not choose to repair.
This is an old chrome plated steel wagon wheel type rim for his '73 highboy. Does anyone have a line on some that are for sale?
AnoldDog
What do they look like and what size are they?
I have a set of chrome wagon wheels I just pulled off of my truck. 15" I think that two of them are 8" and two are 8.5"
They could be yours for the price of a stock rim.
Jd
Jd
Anyone know of or have a 66-72 F2-350, or 80's diesel F350 they'd like to donate to me? I'm looking at doing an unusual diesel swap(DT466 from an IH truck), so it's preferred to have no engine or trans. Axles aren't necessity either, but helps in rolling around. There's a nice rig in the classifieds for $500, but it's in MN. A 12V Cummins is a great engine, but it's becoming too common, I'm looking for some shock factor
Jim
Jim
I have a '75 F-350 Super Camper Special with no motor or transmission. I'm selling the bed, cab, front clip, pretty much everything except the frame and the suspension.
If you're interested, send me a message. Thanks.
Jim
I have an original cast iron 4 bbl manifold for a FE - came off a car 390, about a 63 model. I also have several holly 4 bbls, all are rebuildable. I will take $25 for the manifold, and $45 each for the carbs.
PM me for pictures/details.
