Tire Size?
Old Sep 11, 2006 | 01:14 PM
david00f150's Avatar
david00f150
Tire Size?
What is the tallest tire you can fit on an 87 F150 4x4? 31? 33? 35?
Old Sep 11, 2006 | 01:27 PM
'88_F-150's Avatar
'88_F-150
without rubbing probably 31's but there are many threads on this topic if you do a search
Old Sep 11, 2006 | 01:30 PM
andym's Avatar
andym
No lift? 31's but they will rub the radius arms.
Old Sep 11, 2006 | 01:44 PM
'88_F-150's Avatar
'88_F-150
i have 31's on my 2wd and they dont rub at all
Old Sep 11, 2006 | 01:47 PM
andym's Avatar
andym
They will rub on the stock wheels. You probably have more backspacing than the factory wheels.
Old Sep 11, 2006 | 04:27 PM
david00f150
So what do ya'll think w/ a 3" body lift?
Old Sep 11, 2006 | 04:28 PM
david00f150
I guess looks can be decieving because it sure does look like I could fit at least 33's at stock ride height.
Old Sep 11, 2006 | 04:39 PM
andym's Avatar
andym
Probably, but the first time you flex the suspension at all, they will hit something.
I don't think you should get a body lift at all. If you want to lift it, do it right, with a suspension lift. If you want 33's, get a 4" lift. 6" will let you clear 35's, but I believe you will have to space the front bumper out a bit.
Old Sep 11, 2006 | 09:07 PM
david00f150
Well I don't have a stock bumber. Its an aftermarket bumber for mounting a winch.
Old Sep 12, 2006 | 07:05 AM
bob1987f's Avatar
bob1987f
ive got 32x11.5's on my 87...and no rubbing....stock lift.
Old Sep 12, 2006 | 03:17 PM
Bulldog66's Avatar
Bulldog66
I've 6" of Rancho lift and 35" Baja M/T's. I could go with 38" but there's a chance under flex/load they'd still rub and it's just not worth the chance.
Also, be sure to consider stopping effort and distance as well. Bigger tires = more stress on stock rotors/drums, etc. I know w/ my set up, I notice a diff on stopping.
(95' F250 4x4)
Old Sep 12, 2006 | 04:00 PM
Conanski's Avatar
Conanski
31's rubbed on the passenger side radius arm only at full lock on both my F150s.. an '89 and a '90. I also have 265's on the factory wheels which are slightly taller than 31's on 8" aftermarket wheels, and they exhibit the same issue.. which is minor a best.
I don't think I could stand driving it with larger tires though, I really noticed the change in acceleration, so I can't see going to 33's or 35's without 4:10 gears.
Old Sep 12, 2006 | 04:21 PM
Jakeman711's Avatar
Jakeman711
What size engine do you have? That would be my question. Transmission is another issue. If you have an auto I would recomend that you change your diff gears before going too large with your tires. I had a friend that put 35's on his truck and didn't change his gears, and about 3days later his trans went. Wore out the cluches and bands because there was so much slippage. Just my opinion. I think 31's would be ok. -Jake
Old Sep 12, 2006 | 05:00 PM
david00f150
Its an 87 F150 4x4. I have a freshley rebuilt 302 with ported heads, 204/214 cam, and edelbrock intake. I have an auto C6 tranny w/ 3.73 gears and a dana 40 limited slip rear end.
Old Sep 12, 2006 | 09:09 PM
bigsexy63's Avatar
bigsexy63
i had 33x12.50 bfg all-terrains with 15x10 inch wheels on my 89 f-150 stock the y only rubbed a little bit on full turns nothing extremely noticable. also i have a 351 w.
