Sponsored by: Real Truck
05 f250 ac problem
Old Sep 7, 2006 | 01:29 PM
superdutyquest's Avatar
superdutyquest
05 f250 ac problem
when the selecter is on max/ac the air is directed onto the windshield like it is in defrost mode.has anyone else experienced this.i want to try to fix this problem myself so i dont get reflashed at the dealer if i bring it in for the warranty to cover it.
Old Sep 7, 2006 | 03:23 PM
FortyFords's Avatar
FortyFords
Sounds like a vacuum leak or a bad blend door actuator.pull the passenger glove box open and squeeze the sides in to get it to open further.
Behind the glove box is the ac/heater plenium with the actuator ,chk for it's operation when using max ac.
also if you have a vacum leak in the system the default always puts the ac/air to the windsheild.
Common vac leak areas are the front hubs ,if you have esof 4x4 hoses fall off or crack
on the back of the front knuckle.
Let us know what you find.
Rich
Rich
