Sponsored by: Real Truck
Just a Tuner?
Old Sep 5, 2006 | 04:14 PM
haulingboat's Avatar
haulingboat
Just a Tuner?
I have a 02 crew w/7.3 and 4x4. Will a tuner alone (without exhaust and with a K&N air filter) improve my mileage, acceleration, and pulling power enough to justify the $350?
Thanks.
Old Sep 5, 2006 | 05:26 PM
VQ2Fast4U's Avatar
VQ2Fast4U
Without intake and exhaust upgrades you will most likely have high EGT's, the power and mileage improvements will be there, but you might not be able to use all of the power or see the "best" mileage. I say if you got a set of gauges go for the chip/tuner and see how it goes. Also try posting in the 7.3 forum you will get more feedback for a question such as this.
Old Sep 5, 2006 | 06:07 PM
haulingboat
I know the more air you can move in and out of the motor the better it will run. I belive I currently have 3.73 gears in the back. With the 35" tires and four inch lift the truck is sluggish at the gun. I do pull heavy loads often and would appreciate the extra giddy up.
I can always add exhaust and intake later right. Do the Higher temps damage the motor, pistons, or heads?
Old Sep 5, 2006 | 06:41 PM
ReAX's Avatar
ReAX
Approx 2mpg is what my customers see. Some with other mods claim they have gained 4-6mpg.
The high egts cook the turbo, but on a low power setting you shouldn't have a problem.
Old Sep 5, 2006 | 07:54 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
throw in a set of gauges first, then chip it, then exhaust
Old Sep 5, 2006 | 08:07 PM
VQ2Fast4U's Avatar
VQ2Fast4U
"I" would not run any sort of tuner/chip in my truck without gauges. If you tow I think that would be your best investment if you dont have them already. If you want to save some money go with the "kiwk filter" mod, straight pipe your exhaust, and go with a tuner/chip of your perference. I plan on hacking off my muffler when the rain stops up here in CT. Im also looking at buying a DP Tuner sometime next week. If all you want is a little more "go" off the line, then I think you will be able to do so without breaking the bank. If your towing heavy re-gearing might be something to look into, but its not cheap and wont help mileage. But I cant stress gauges enough, motors, trannys, and turbos arent cheap.
Old Sep 7, 2006 | 11:00 AM
haulingboat
Thanks for the replies. Everyone recommends the gauges. I believe I will have them installed first. Where are you guys installing them? Do they look nice? I do not want to look like a fast and furiuous ricer. I'd like something a little more stylish.
When you cut the muffler out of the exhaust is the noise in cab really loud? I ride a harley with straight pipes, so I know it will be louder, but I prefer a quite ride in truck.
Thanks again for the comments.
Old Sep 7, 2006 | 11:18 AM
Lonewolftx's Avatar
Lonewolftx
Arrow A Piller . . .
3 gauges on the A piller, I like auto meters, Tranny temp, boost, & Exhaust temp. Paint the holder to match interior . . .
Typical setup
http://www.dieselsite.com/index.asp?PageAction=VIEWPROD&ProdID=57
Old Sep 7, 2006 | 11:40 AM
haulingboat
Thanks lonewolf. I understand the tranny and egt gauges, but what is boost? The turbo? What does the gauge measure?
Old Sep 7, 2006 | 11:53 AM
Lonewolftx's Avatar
Lonewolftx
Arrow It's a 6.0 thing . . .
It measures the amount of boost the turbo is putting out. Whenever you get heavey on the pedal you need to monitor the boost level as to not damage the turbo.
I notice you are not running the 6.0 turbo, 2002, so you might want a two guage set up or add another engine gauge.
Old Sep 7, 2006 | 12:11 PM
haulingboat
The two gauge set up would measure what? The boost and tranny? Or the tranny and egt's? Are the 7.3 turbos more reliable than the 6.0? Do I need to gauge the turbo any ways? I have a factory tranny temp gauge in the dash. Do I need a second?
Old Sep 7, 2006 | 01:12 PM
Lonewolftx's Avatar
Lonewolftx
Arrow Your choice . . .
The gauges can be whatever you want them to be. My '06 has a boost & tranny guage on in the instrument cluster but I wanted a "better" guage for accurate mesurements.
Also the bigger Piller guages are easier to read for me. Hence my 3 guage setup; boost, tranny temp, & exhuast temp. You can choose whatever guages you want to have. This is the most tyupical setup for monitoring what is going on under your hood. Tranny temp for overheating while towing. Boost output for monitoring the level of boost annd Egt temp for monitoring how hot the engine is getting putting out power while towing, racing the guy next to you, etc.
It is all up to what you want to look at and monitor.
Old Sep 7, 2006 | 01:29 PM
haulingboat
tHANKS
Thanks for the advise. I think I know what I want. See ya on the road way.
Old Sep 7, 2006 | 10:50 PM
Customz's Avatar
Customz
I second that. And upgrade to the donaldson intake kit from the 6.0L. You'll increase the flow and filtration.
I'm sorry but 4-6 mpg gain is a pipe dream and I don't buy it...not even for a dollar on a 7k lb truck.
