97 FXLT - push brake pedal -won't shift gears?
Hi - When I press down the brake pedal and try to put the truck into D or R using the dash monted shifter it doens't want to move out of P. If I press really press hard on the brake pedal and shimmy and play with the shifter it will change gears but it's getting more and more difficult to do. Let me know of any suggestions. thanks. 97 f-150 XLT 4X2, 215,000 miles.
Originally Posted by mlacien
Thanks - getting the recall done tomorrow morn. The break lights do not go on unless I push down with ALOT of force then they light up and I can shift gears too.
-mike
-mike
The switch may be worn or out of adjustment. Otherwise, the wires to the switch connector have a tendency to break inside the insulation and will need replacement.
If you need to get the selector out of PARK, you can just turn the key forward one position (before RUN), shift into Neutral, then start the engine. Once started, you can then shift into D or R as needed. The shift interlock, which is turned on by the brake light circuit, only affects the ability to shift OUT of Park.
Steve
mox-ct
10-11-2009 07:45 PM
