'63 F-100 Front Wheel Cylinders
Old 11-25-2001, 05:49 PM
saxdaddy's Avatar
saxdaddy
saxdaddy is offline
Where can I get new front cylinders for my '63? All I can get is rebuild kits and the cyl. is beyond help... This one is the single piston type and no one seems to have these. I can hardly drive the truck as it is, due to the wheel nearly being snatched outta my hand when I apply the brakes. Any help with this would be appreciated..
Old 11-25-2001, 07:25 PM
jjb's Avatar
jjb
jjb is offline
Try calling Joblot Parts in NYC phone number is 1-800-221-0172 they might have the part Good Luck !
Old 11-25-2001, 10:26 PM
Rosati's Avatar
Rosati
Rosati is offline
Try Kanter Automotive Online. They may have them since they specialize in brake and suspension parts for old cars and trucks.
Krosati
Visit my homepage at ClubFTE
[link:www.clubfte.com/users/krosati/index.html|My Homepage]
My friends say I'm too old to play with toys.
I need new friends
Old 11-26-2001, 08:17 AM
cobraguy's Avatar
cobraguy
cobraguy is offline
I've still got my stock front end with good brakes dual piston whl cyl . It's junk to me I'm in San Diego. Email me at shelekelley(No Email Addresses In Posts!) if you want any of it. Rich Kelley
Old 11-26-2001, 08:24 AM
airharley's Avatar
airharley
airharley is offline
You may want to consider having the cylinder relined at a machine shop. They will basically bore out the cylinder and resleeve it. Cut down on having to buy a new one or find that the one you bought to replace it with is bad also. I did it with my '60 on the wheel cylinders and slave cylinder. Just a thought.
Old 12-02-2001, 10:35 AM
62stepside's Avatar
62stepside
62stepside is offline
I had the single cylinder brake pistons on my 62. I spent 3 months trying to track new/rebuilt units down using the casting numbers and finally gave up. The dual piston units for a 64 fit perfectly, just had to find two more connecting rods between the piston and the shoes. In the manual there is no difference between the brake setup aside from that single piston unit. I found mine at AutoZone. You have to be carefull though... The newer castings sometimes have metric bleeder screws. Makes it a pain to bleed your brakes when you have to use 2 different wrenches.
Tyson
'71 F100 Partial Resto (sold - wish I hadn't)
'62 F100 223 I6 (in peices - frame off in progress)
'53 F100 Just bought it, someones unfinished project
Old 12-02-2001, 10:34 PM
iwojima's Avatar
iwojima
iwojima is offline
Post '63 F-100 Front Wheel Cylinders
pburress
18
09-13-2019 04:37 PM
biggut
08-29-2013 09:57 PM
dads 63
05-16-2012 04:55 AM
TallBoyB.C.C
1961 - 1963 F100 Unibody
10-18-2011 09:29 PM
Andy63
03-21-2003 08:35 AM
Quick Reply: '63 F-100 Front Wheel Cylinders
