Thanks! Now A Miss.
Thanks! Now A Miss.
This started with an engine that would not start. With all the help (MANY THANKS FOR THE HELP) I worked my way through testing and treating. The outcome (after$1100) turned out to be low oil in the hpop. Now it starts and runs, but has a miss again. I am so glad to have it going I am letting it run with the miss and to charge batteries again. How did hpop get low? how big a problem is it? Is it causing the miss? I am thinking of trading it off. I can do it running better than not even if it does have a miss. Jerry
How did hpop get low? Jerry
IIRC There are only a few things that can result in low hpop oil level: Lpop can't feed enough oil to it or anti-drain back valve needs attention (stuck).
I don't know if low hpop will develop a miss in just one cylinder, but it can make all the cyliders (injectors) act up.
