Can You Get To Your Spare Tire????
#46
#47
heres how mine is mounted, i put the spare where i was wanting it mounted and marked the inside lip of the bedrail, i took a small (1/4") u-bolt and using my mounting mark used that as a centerline for it, drilled the 1/4" holes, used a dab of silicone to prevent rust when i slid the U-bolt on and tightened. found a J-bolt (its a 3/8" i think) and it hooks into the bed-mounted U-bolt, the stud goes through a lug hole in the spare. have a chunk of rubber cut from a old mudflap, a washer and finnally a nut to secure it all. would like to find or make a big 3/8" wing nut. i keep a old small cresent where the jack is stored so i can remove the tire if needed out on the road. the spare in the trailer is a simalar deal, but uses hardware from a g.m. car, a 1/4 j-bolt and big wing nut as well as the large washer with a 1/4" hole.
#49
time to revisit this thread
4 years of corrosion and rust seized the spare tire carrier solid ...again
amazingly the tire held air but it took 1/2 hr. a long pipe, and a bunch of wd-40 to get it loose....
it was the eye bolt that holds the wheel to the carrier that presented the most difficulty.
it was rusted badly.
all back in operating condition and this time used heavier grease on all moving parts...
hopefully that will help.
#50
Just finished dropping mine down for its annual check up. Tire needed airing up, which I do at the Max sidewall figure, as air is always leaking out.
My 99 has the cable/"T"bar suspension/carrier arrangement & I lubed the cable with Marine grease a few years back & its still on the cable & the cable is still rust free.
You folks in the rust belt, that have the frame type spare tire suspension/carrier system, check that puppy out before you need it some dark night out in the middle of nowhere & find it rusted in place, or the spare flat!!!!!
#51
oh no...
driving out to the airport the other day got the awful exhaust is dragging on the road scraping sound.. no ...the spare tire carrier dropped down. turned out the hinge holding the carrier up sheared clean off. problem is the pin inside the hinge (both sides) is solid frozen in there. tried to punch out .. wouldn't move. any bright ideas how to jury rig somehow to keep the carrier up?? i've got it wired in the up position to the frame now but it won't support the weight of the spare.. which is residing in the bed..
#52
#54
time to check the spare
i have been driving the 'new to me' '02 ranger for a couple of months now. it was time to check the spare.
it has the cable system.
cranked down ok and found an unused goodyear wrangler, likely from the factory.. the cable still looked bright and shiny so i coated it with a good layer of grease, as well as the tbar/spring at the end . the steelie rim had some surface rust.. not too bad at all.
finally, cleaned up both sides of the tire and added air ( it only had 10psi in it ) , and wound it back up . needless to say, i'm glad i checked it...
#55
I am sitting here cringing after reading this thread, I have a 2011 Ranger, bought about 2 years ago and I realized I haven't checked the spare since it was bought. My real problem is that my truck is in Atlanta and I'm in Abu Dhabi. My son is at home and if it was a computer problem there isn't anyone I'd trust more but a mechanical issue is another thing all together. So I know my first task when I return in November....... Thanks guys!
#56
#58
Thank you for reminding me to drop my spare and mount it somewhere else. The last time I dropped it a few yrs ago I had to fight with it for an hour but I lubed it all up before I put it back. I hate the tire there.
We have an old toyota truck that has the same setup, it was rusted solid I had to wait until I removed the bed for some welding to cut the thing loose.
Not a design made for the rust belt.
#59
well it's been 2 years since the initial inspection so time to do another check on the spare. pleasantly surprised tire held 35psi and the cable was in good shape from the previous greasing. rattle can generic ace hardware rustoleum works great on the steel rim! grease everything again and put it away for hopefully another 2 years...
#60
I have a different problem with spare. I had to drill out my lock because I didn't get the key with truck. 2000 Mazda so it has the cable setup. When I put the jack handle in it isn't long enough to put on the lug wrench to turn it ( it doesn't extend past the bumper/tailgate ). I had 4 identical handles in my toolbag - no extensions. What I do is put a screwdriver in the square of the handle and turn it with slip joint pliers. Should I have had an extension or a longer handle in case lock had to be removed? This is a real pain!
