Bent In My Truck Bed
Today, while heading out to do some riding on my quad, I had to make a quick stop for a light. While slamming on the brakes my quad broke loose from my tie down holding the back on the quad back and rolled foward hard and smashed in the front of my bed into the cab. Lucky I still have a rear window. I couldn't believe it. Well got home and got it bent back but now looks terrible!
Was wondering if there is some kinda plastic or metal piece I could buy that would cover that top railing of the bed so that is doesn't show all the bent up metal. I'd apprciate any feedback. Thanks.
Ouch! I feel for you. That is a tough hit. I don't know off hand if they make any kind of front railing cover. What I would do it to use a length of angle iron, maybe like a 1/4 inch thick by 2"-3" wide and run that along the top of the railing. Not only will it cover the damage, but it will reinforce the railing as well. Good luck.
apparently the previous owner of my truck had something like that happen, but not that extreme. you can clearly see in the middle where something hit the top of the rail and pushed it towards the cab. i noticed it when i was doing my bedliner, the paintbrush got closer to the cab but i wasnt doing anything different.
Without seeing your truck, I can't make a determination as to how big (wide) of a piece of steel you would need to cover it. I (hopefully) assumed a 2"-3" would work. Of course, you could simply modify this by adding a flat plate enough to cover the damage. Properly secured, this would actually by much, much stronger than the OEM railing by far.
I own a custom motorycle that I have trailered on occassion which is actually worth more than the truck, so I make sure she is strapped down good. I use a sissor jack to raise it off of the shocks and attach the straps directly to the frame. No room for error.
Maybe post a pic if you can.
sum_weirdo
02-22-2013 06:08 PM
AIbandit
36
11-28-2011 07:02 PM
