Modular V10 (6.8l)
code help
Old Aug 24, 2006 | 04:48 PM
duckhacker's Avatar
duckhacker
code help
2 different autozones have told me different meanings for the following codes on a 99 f250 6.8 v10:
P0171 & P0174
One advised me to the MAF sensor while the other said it was my o2 sensors(all of them).
Any ideas or help?
Thanks
Jacob
Old Aug 24, 2006 | 05:00 PM
duckhacker's Avatar
duckhacker
just did a search and hopefully found some answers
Old Aug 24, 2006 | 05:14 PM
biz4two's Avatar
biz4two
Arrow
Here you go...
P0171 OBD-II Trouble Code
Technical DescriptionSystem Too Lean (Bank 1)
What does that mean?
Basically this means that an oxygen sensor in bank 1 detected a lean condition (too much oxygen in the exhaust). On V6/V8/V10 engines, Bank 1 is the side of the engine that has cylinder #1.
Note: This DTC is very similar to P0174, and in fact your vehicle may show both codes at the same time.
Symptoms-
You will more than likely not notice any drivability problems, although there may be symptoms such as a lack of power, detonation (spark knock), and/or a hesitation/surge on acceleration.
Causes-
A code P0171 may mean that one or more of the following has happened:
The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filters (K&N, etc.) can cause the MAF to become dirty if the filter is over-oiled. There could be a vacuum leak downstream of the MAF sensor.
Possible Solutions
Possible solutions include:
In the vast majority of cases, simply cleaning the MAF sensor does the trick. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with electronics cleaner . Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
Inspect all vacuum and PCV hoses, replace if necessary
Check for a dirty fuel filter and proper fuel pressure
Hope this helps...
biz
_______________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Old Aug 24, 2006 | 06:40 PM
FortyFords's Avatar
FortyFords
chk the rubber hose(elbow area) going to the pcv valve.
Common to crack in that area if the maf cleaning doesn't help.
It can also be intake o-ring gaskets or a crack in the plastic intale.
Rich
