1978 - 1996 Big Bronco
Gas milage towing
Old 08-24-2006, 09:12 AM
fishin machine
fishin machine is offline
fishin machine is starting off with a positive reputation.
Gas milage towing
I'm leaving for OH in a few days from VA. You guys got any idea how far my fuel milage is gonna drop off. I'm pulling a 17' boat, total rig ways around 2500lbs. All stock 93 w/ 351w and 3.55 gears in the rear. All my driving will be highway. Normally I can pull 14-15 mpg on this trip without the boat.
Old 08-24-2006, 10:00 AM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
you will probably be in the 10-12mpg range depending on headwind and traffic conditions. the more you maintain a consistant speed the better of course. make sure your tires are at proper pressure if not a tad higher. what size tires are you running?
Old 08-24-2006, 06:20 PM
b4hntn
b4hntn is offline
b4hntn is gaining momentum as a positive member of FTE.b4hntn is gaining momentum as a positive member of FTE.
With two four wheelers on a heavy trailer I get 10-11 mpg with 90% highway.
Old 08-24-2006, 10:00 PM
Fishallot
Fishallot is offline
Fishallot is starting off with a positive reputation.
I have the same truck/motor except a 96. I also pull a 17' center console boat all the time. I get a 2-3 mpg drop pulling my boat however that's stop and go driving. You should do better on the highway. Try to use the cruise control once you get up to speed and you shouldn't lose to much mileage.
Old 08-25-2006, 03:24 PM
scootin
scootin is offline
scootin is starting off with a positive reputation.
I'll chime in...
I routinely pull a 17' boat, w/ same weight as yours, from Cincinnati surrounding lakes in Ohio (Eastfork/Grand Lake St. Marys/Caesars Creek/Rocky Fork), Kentuck (Cave Run/KY Lake/Dale Hollow/Laurel) & Indiana (Brookville). On highway, with plenty of ups and downs, I get a consistent 12 MPG. I have the 302 w/ 31" rubber. Don't know if anyone else mentioned it, but I always turn off the overdrive - the tranny just hunts too much with the hills.
Where ya heading to in Ohio?
halaferd
22
02-11-2013 04:12 PM
bradsurfs
28
12-18-2012 10:17 PM
gabocar
1997-2006 Expedition & Navigator
10-21-2008 01:02 PM
stan_02ranger
Oil & Lubrication
52
05-03-2007 12:45 AM
Don Brill
Computer Chips & Tuners
11-18-2005 10:15 AM
Quick Reply: Gas milage towing
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
