quick question
Old Aug 24, 2006 | 08:39 AM
wheressinatra's Avatar
wheressinatra
quick question
Hi Everyone.
Will 29 X 10.5 - 15 tires fit on a stock 1970 F100 wheels. I have a 15'' wheels, but I don't know if they will handle the 10.5. Thanks in advance for any help.
Jake
Old Aug 24, 2006 | 08:57 AM
390fe's Avatar
390fe
I had some 31x10.5's of stock Ford wheels. They fit, but the tire wore in the center of the tread because the tire was so wide.
Old Aug 25, 2006 | 08:58 PM
1972FordCustom's Avatar
1972FordCustom
if it wore in the middle, it was more than likely from tire pressure than the tire being too wide....
Old Aug 25, 2006 | 09:04 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Rim width match tread width?
Undersize rims are ok for off road only to protect the sidewalls from damage. Heck you can mount 10.50's on a 4" wide rims that doesn't make it right or cause center tread wear from over inflation. It will handle like a wart hog in the twisties.
.....=o&o>.....
Old Aug 25, 2006 | 09:07 PM
1972FordCustom
Undersize rims are ok for off road only, heck you can mount 10.50's on a 4" wide rim that doesn't make it right or cause wear from over inflating.
.....=o&o>.....
any tire will wear from over inflating. it dont matter what size tire on what size rim
Old Aug 25, 2006 | 09:17 PM
"Beemer Nut"
12.00 x 33 x 16.6 tires on 9.75" rims the only rim width recommended for that tire will wear the centers from new with only 18 psi on the rear of a empty truck. When parked the center tread area is 3/16" lower than the outside tread, the tires balloon out or grow at highway speeds in the center like top fuel rags. Mount 13" Pinto tires on a 8" rim then inflate to 50 psi the edges will wear before the center does. Extremes taken to both ends of the tire rim combinations and people have done it. Just a little persnickety tonight.
.....=o&o>.....
