Can A/C be added to an XL F250 V10?
Go to a local AC repair shop and see if they will install an aftermarket kit.
I'm sure they are available.
If you are going to do the work yourself, it should be pretty straightforward.
Go to a junkyard, find a donor SD, take the condensor, the heater box/evaporator, compressor and mounts, hoses, dryer, and take a picture of the belt routing diagram under the hood
Buy a new dryer, and put it all together.
You probably need the controls for the dash too. Wiring might be a pain, but certainly doable.
I'd leave a weekend or two to do the job myself...
sw20td06
Ford Truck Parts for Sale
01-24-2017 10:33 AM
