how do i increase my MPGs?
This is a well discussed question but I'll give you a summary. Make sure you're tires have the correct air pressure....less resistance with the road and the engine has to work less. Use synthetic lubricants...again less resistance. Of course there are the mechanical mods like cold air intake to increase air flow into the engine. A high flow exhaust to match the increased air going in with the crap going out is also needed. On top of that a performance chip will help. The last step is a programmer to make sure the new bits and pieces are working nicely together. You can do any of these steps separately but for the best results all the steps needed to be packaged together.
I'm sure others will have more suggestions...spark plugs, plug wires etc etc.
What axle ratio are you running, and do you do a lot of highway driving? I'll assume that it's currently in good tune and that you are not running an agressive off road tire. BTW, even BFG KO's result in a mileage hit, believe me from personal experience. Wider than stock tires also come with a potential mileage hit.
*Is your odometer accurate thus enabling you to calculate the correct mileage? Every now and then I read about someone that has put on larger diameter tires and *thinks* they took a mileage hit. Also, unless you have your foot in it constantly, you'll probably be dissapointed with mods that allow it to breath easier.
Received 3,090 Likes
on
Originally Posted by F250FarmBoy
yeah,i do alot of highway driving to get to school. i dont know of the gear ratio but i'll check.
thanks again.
thanks again.
You put that vacuum gauge in a prominant place on your dash where you can see it all the time. When you are driving, use your throttle foot to keep that gauge at the highest reading that is practical.
Also, run tall skinny high pressure tires.
Set your front end for zero toe and zero camber.
Get rid of big mirrors, bug shield, visor or anything else that creates drag.
Check to be certain that your brakes don't drag.
Run the lightest allowable lubricants in the engine, trans, transfer case and diffs.
If you have a rack or camper you can do without, get them off the truck.
Unload any extra weight you carry.
Consider a chin spoiler.
