I have a 77 F250 with a 351M and a 4speed tran. After a valve job it is runing warmer not hot,But warmer.I was thinking of changing to a cluch fan instead of the stright one that is on it.
Can someone explain the pro and cons of this,And is this a bad decision
Thanks Don
Thanks Don
Don't know. :/ But sounds to me like you are going the wrong direction.
Clutch fans are for quieter operation and better gas mileage and not-towards more cooling.
A clutch fan will cool better in most cases. I installed one on the 460 that I put in my 77 and it has never run hot. The blades usually have a more aggressive pitch and pull more air at low speeds, then loosen up at higher speeds to free up power and mileage.
A good 7 blade clutch fan with a thermostatic clutch will cool great.
A clutch fan will cool better in most cases. The blades usually have a more aggressive pitch and pull more air at low speeds, then loosen up at higher speeds to free up power and mileage.
Yeah didn't think about the fan blade being different. Thanks.
