2001 F150 axle seal/ advice
Hi. I'm new to these forums. Just a country boy. I am looking for a little help on replacing rear axle seals on my 01 150 4x4. Have done considerable wrenching in the past, but never on anything newer. Looking for some source for free repair manuals or tech advice online. Is that possible, nothing is free. Hope you fellow ford guys can help. Thanks
Welcome to the forum
I don't know of any free online manuals that will help much. You might want to consider buying a manual for your truck for now and any repairs you might do in the future. It will probably be a good investment.
Replacing the seals is pretty easy. Basically you remove the wheels, brake calipers and rotors, rear diff cover, remove the spider (pinion) shaft, C-clips and then the axles.
Besides the new seals you'll also need some brake cleaner for cleaning the parts, RTV silicone for resealing the diff cover, approx 3 qts of 75W140 oil and a bottle of friction modifier to add to the oil if you have limited slip.
rawarder
06-28-2005 12:32 PM
