Syncing Speedometer with Edge Evolution
Old Aug 10, 2006 | 09:42 AM
Flynnd27's Avatar
Flynnd27
I put the Edge Evolution on my '06 F-150 4X4 S-Crew with Ford 20" stock wheels.
The book that comes with the Evolution does not list the 20" stockers for entering in to the custom settings. It does, however, have the formula to calculate the correct numbers.
I worked the formula and came up with a number and then to see if I was using the formula correctly I put the numbers in for 17", 18"s like they have in the book and came up with answers that were always 1 number off from what they have listed. Usually the Evolution book is one number lower than what the formula puts out. But in at least one instance the number was one higher.
I am not sure if I should lower my number by one or what to do? My truck's Speedo always seems to be a couple of mph's faster than the edge. I drove down to Moab, Utah last week and past a couple of the speed limit signs that tell you how fast you are going... each time my speedo was several MPH's off from the radar sign.
Any suggestions?
By the way, so far I really like the Edge Evolution.
Old Aug 10, 2006 | 11:25 AM
WhëëlMå1's Avatar
WhëëlMå1
Well it says in the Edge manual that you can be +/- 3mph I think due to slight variances in the Ford speedo assembly. Past that, I would trust the numbers that you get from the Edge calculation.
Old Aug 10, 2006 | 02:23 PM
TRX250R87's Avatar
TRX250R87
Edge Evolution
I found that my GPS matches the Edge MPH exactly. The spedo was off by 2 MPH compared to the Edge and GPS. I think the spedo is 2 MPH slower.
ERIC
Old Aug 10, 2006 | 11:25 PM
Flynnd27's Avatar
Flynnd27
Will my speedo being fast affect my Odometer?
Old Aug 11, 2006 | 06:29 AM
TRX250R87's Avatar
TRX250R87
spedo
Yes it will.
Old Aug 11, 2006 | 08:46 PM
derek4343's Avatar
derek4343
when i talked to the tech,he said that ford speedo's are about 2 mph's off.your edge is correct. mine reads 2 mph faster.
