escort ignition wiring...
Old 08-09-2006, 09:08 PM
nhswrld's Avatar
nhswrld
nhswrld is offline
so i have this 91 escort with the 1.8 dohc engine in it...the ignition lock switch is shot and a new one cost a pretty penny so i figured i could just hook up a switch and a push button .....the push button would be the starter and the switch would simple be the key in the "on" position, but i dont know what color wire is what...there is a six wire plug and also a two wire plug that go into the ignition lock switch....does anyone know which wire is which?
Old 08-11-2006, 08:28 PM
TigerDan's Avatar
TigerDan
TigerDan is offline
Here's something easier. If it's actually the lock that's shot, look at the bottom of the ignition switch assembly. There's a black plastic section that's held in with 1 scew and a clip. Remove it the screw and pull on the clip and slide it out, it's the actual electrical switch You can leave it hang and actuate it with a screwdriver till you can get another lock assembly. (Might try a wrecking yard to save some bucks.)
I went through this on my dad's old '91 Tracer (same car) but I just bought another switch and lock assembly complete from NAPA. I think it was about 60 bucks IIRC.
Old 08-12-2006, 07:44 AM
nhswrld's Avatar
nhswrld
nhswrld is offline
60 bucks aint bad, i actually rigged it for now....i popped the guts out of the ignition and "broke" the locks out inside then slide it back together...so i can pretty much start it with anything but it still looks like the normal key ignition
Old 08-12-2006, 10:21 AM
TigerDan's Avatar
TigerDan
TigerDan is offline
That's even better. Nothing like having your ignition all busted up and taken apart, you ever get pulled over and the cop takes one look and assumes you stole the car!
I guess they're a troublesome part on those cars, my dad had problems twice with his. First it was the electrical switch portion, and then the lock itself.
Old 08-12-2006, 10:39 AM
tomw's Avatar
tomw
tomw is offline
If you have the patience of a saint, and the hands of a jeweller, you can fudge the old electrical switch apart, clean and lube the connectors, and re-assemble it. I had one where the switch down further on the collumn, moved by a metal rod, would make intermittent contacts... Not fun going down the road. Took it apart, cleaned and reassembled, and it was fine for years
tom
Old 08-15-2006, 11:19 AM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Parts Guy Wyatt is offline
Former Vendor
ing switch F5CZ 11572-AA FACTORY OEM FTE$47.26 plus shipping, in stock!
Ed
Tartersauce53
28
12-18-2016 05:46 PM
Jeff Ranger
07-09-2015 10:02 PM
blueoval4ever
06-01-2012 06:12 AM
staysbroken
11-18-2010 09:05 AM
bwoldschool65
09-29-2009 06:33 PM
Quick Reply: escort ignition wiring...
