More radiator questions/problems
Old Aug 7, 2006 | 03:38 PM
clev's Avatar
clev
I'm waiting for the 203 t/stat, so I decided to put the old one back in and do good flush out. Three times I installed, uninstalled and reinstalled the t/stat and housing before it was finally leak proof. What a pain!
Next problem: the t/stat doesn't appear to be opening. The top hose is not pressurized and the top can be screwed off of the fill bottle without hearing any air. I drove it for about 3 hours (per instructions on the SuperFlush bottle), the idiot gauge climbed slowly to just below the middle position and stayed there. That's where the gauge always pointed so I don't know for sure if the t/stat ever opened. Any suggestions and what I should do at this point?
Old Aug 7, 2006 | 03:46 PM
PSNut's Avatar
PSNut
Your positive the old one was reinstalled correctly?
Nut
Old Aug 7, 2006 | 04:03 PM
Cuda_jim's Avatar
Cuda_jim
Sounds like the old stat is stuck open, not closed. Takes a long time to heat up when that happens.
Old Aug 7, 2006 | 04:28 PM
clev's Avatar
clev
Hi PS, thanks for the quick reply. No, I'm not sure it's installed correctly. I posted previously about that. An article that I read on another site stated that the arrow on the t/stat should point to the rear bolt on the housing. My t/stat had the arrow pointing to the front and the brass air bypass at the rear. I don't know if that makes a difference or not. Regardless, I put it back the same way. Can you shed some light on this direction problem?
Cuda, the t/stat is not stuck open. I had it out and examined it; it's fully closed. Even if it is open, after about 3 hours of driving, shouldn't the fill bottle and top hose develop pressure?
Old Aug 7, 2006 | 06:34 PM
clev's Avatar
clev
I mentioned before that I'm new to working on diesels, so guys and gals I could really use some advice on the direction and lack of pressure. Any help would be greatly appreciated.
Old Aug 7, 2006 | 07:55 PM
Uzumati's Avatar
Uzumati
Clev check out you other post I found out about the arrow ? you had
Old Aug 7, 2006 | 08:02 PM
Cuda_jim's Avatar
Cuda_jim
clev, you said idiot gauge climbed slowly. If this is true then the stat must be opening too soon and sticking open. A weak spring will cause this and when you remove it, it can be in the closed position appearing to be OK.
If the stat never opened you wouldn't have gotten very far. Major overheat!
No heat or not enough heat, no pressure in the system or you have a bad cap, won't pressurize.
Old Aug 7, 2006 | 08:10 PM
clev's Avatar
clev
Thanks amiller; Bob @Dieselsite responded to my e-mail and he stated that if the t/stat is mounted horizontal, it doesn't matter which way anything points. If it's mounted vertically, the vent must be at the top or in the absence of a vent, the arrow must be pointed up. Mine is horizontal, so it doesn't matter. Thanks for your replies.
cuda, bob also responded to the issue of no pressure. He said that the w/pump had a big air bubble in it and I should remove the heater hose to the pump. I'm still waiting to see if I do that while it's cool or after it's warmed up. As far as 'stuck' open; wouldn't the system still build pressure? As it is, the gauge is reading normal, but the top rad. hose can be squeezed flat and the top taken off the bottle with no air or pressure escaping.
Thanks to both of you for taking the time.
Clev
