no feul
Old Aug 7, 2006 | 02:35 PM
GOTH_TRUCKER's Avatar
GOTH_TRUCKER
Smile no feul
ok,i have a 84 150 300 l6 with a non feed back carb and ds2 ignition on the choke i cant get to work idk why it just doesnt move when i hook it up,so idk,and the thing will only fire over if im choking the hell out of it,and i have a brand new fuel filter and plenty of pressure thru the fuel line and its a brand new carb and i have a orange spark,so wut ya'll think?
Old Aug 7, 2006 | 03:01 PM
marioc956's Avatar
marioc956
What kind of carb do you have,
Old Aug 7, 2006 | 03:53 PM
GOTH_TRUCKER
its a 75 model carter 1 berral carb non feed back
Old Aug 7, 2006 | 04:18 PM
marioc956's Avatar
marioc956
Have you tried the fuel/air mixture screw, and does it squirt gas when you pump it
Old Aug 7, 2006 | 04:20 PM
GOTH_TRUCKER
ya it pumps but not a whole lot so i adjusted i all the way rich and it still doesnt shoot much in there,so idk
Old Aug 7, 2006 | 04:21 PM
Oaktree's Avatar
Oaktree
When it does fire is it running rich ? you could have too little fuel coming out the carb,or too much air(vacuum leak) .
Old Aug 7, 2006 | 04:22 PM
GOTH_TRUCKER
well i can choke it all the way and it doesnt flood so idk wut that means,vac leak?
Old Aug 7, 2006 | 05:17 PM
Mil1ion's Avatar
Mil1ion
Yellow/orange spark = Bad
Blue spark = Good
Quote:the choke i cant get to work idk why it just doesnt move when i hook it up,
Please explain this in detail
Old Aug 7, 2006 | 05:22 PM
GOTH_TRUCKER
ok the choke i hook it up to a full 12v sourse,correct? and it doesnt move at all,like it just sits there so idk
Old Aug 7, 2006 | 05:31 PM
Mil1ion's Avatar
Mil1ion
The Ford chokes require 9 volts from the alternator stator terminal.
The work slow .
They don't fire up like a soldering iron.
Have you indexed the choke at all ?
Old Aug 7, 2006 | 06:51 PM
GOTH_TRUCKER
indexed the choke?
