I have a 2003 F-250 XLT, that did not come with an overhead console. Does anyone know what it will cost to have one installed? Since it didn't come with one from the factory I will assume that it does not have the wiring, or the mounting bracket there. Can anyone give me some info on aftermarket parts, or will I have to go through Ford for this?
I just installed one in my truck,its an f150 console.But it looks good and all i wanted was outside temp and the storge bins.It only took me about 2 hours to install.I bought the kit from ebay.
Can you give us more info? I would like to install one too!
Sure its easy.You have 4 wire to run.Two of which goto the temp sensor and one for power,the other to ground.This guy on ebay sells the whole thing with templet and how to wire them in.You dont even have to remove the headliner,just take off the visors and the little push in things.Then but the wires under the headliner and run them down the a-piller.Then make the conections and your good to go.
Works great.I can get a pic if you want one.
If you need more info let me know.I also can give you the name of the seller on ebay if you need it.
Sure, if you could find the sellers name, I would appreciate it.
He normally has some on ebay,but hes on vaction right now.But should be back shortly.
Just tell him the seller rheaume4883 sent you to him.
He is honest and very helpfull.His directions are easy to follow as well.
Good luck.
