Frame vin
Old Aug 4, 2006 | 10:53 PM
towtruck1's Avatar
towtruck1
Frame vin
I saw a post earlier about the vin # being on the frame. If someone had the hood opened should they be able to look down and see that number? I belive it is supossed to be on the passenger side on top of the frame. i just don't ever remember seeing that numer there!!!
Old Aug 4, 2006 | 11:19 PM
FordBoypete's Avatar
FordBoypete
It's under the batterybox usually so I doubt you'll see it that simply, usually we have to wirebrush the frame top rail flange to really see it.
FBp
Old Aug 4, 2006 | 11:46 PM
Mil1ion's Avatar
Mil1ion
It can be anywhere along there.
It would depend on the line guy actually doing the stamping.
Firewall to rad support amd yes a wire brush is needed.
also another aid is using welder's chaulk on the flat and stroke it across the metal to see the characters better.
Old Aug 5, 2006 | 05:29 AM
460's Avatar
460
On my '76 F150 4x4 that I stripped, the VIN was stamped on top of the frame under the passenger floorboard, half way between the front and rear cab mounts. You would need a mirror to see it if the body was still on the frame. I haven't found it yet on my '79 Bronco frame, although I haven't looked for it much either.
