Not starting '87 inline 6
Aug 3, 2006 | 06:39 PM
I would like to start out by thanking everyone for their help through out my clutch replacment project.
I currently have everything bolted back on except the front drive shaft.
I wanted to start up the beast for the first time in a month and drive it but alas starting is a no go.
It turned over for along time and then after another atempt the starter relay simply clicked.
I discovered that after hitting the starter a couple of times it would turn over a couple more times.
So I am thinking that the starter is sticking in the new flywheel.
But this shouldn't keep the truck from starting.
I pulled the fuel line just before the fuel filter and plenty of fuel poured out.
This is as far as I have gotten in the process.
What I am looking for is advice on where to look for problems or things to test.
It is killing me that I haven't been able to drive my truck, so any help would be great.
Thanks,
Blindlightguy
Aug 3, 2006 | 09:19 PM
Anyone have any advice?
This is so unlike this list.
You all sleeping? Ha!
Blindlightguy
Aug 4, 2006 | 12:02 AM
Is the battery charged? If it's been sitting for over a month then it probably died. Try jumping it off.
Aug 4, 2006 | 03:38 AM
during the clutch replacement, you may have tripped the fuel pump cutoff switch, also called the inertia switch. try reseting it after you have charged the battery.
