61-63 Unibodys
#91
I am in the San Diego County area. Ya the truck is kinda pieced together, the hood came with the truck and is off a different year as well as the grill I have is off of a 63'. I plan on shaving all the emblems off soon anyways. Just gotta work all the other bugs out first and fix some rust then I will start doing what I want to do to it soon.
#92
Add Me!
Put mine on the survivors list.
1961 Unibody short bed, small back window, original 292/3 speed.
Currently stored without engine and tranny. Deciding which way to go. Looking at Crown Vic frame swap/Aerostar front/ MII front/flipped rear/T-bird IRS rear or 4 bar rear. Not sure yet. Probably getting a modular motor.
How about a 1961 Lightening?
There are also 3 others in town. 2 short bed ond one long bed.
SPark
SPark
#93
#94
I have 2
Interesting idea. I have a '61 Merc, M-100, and a '63 Ford F-100, both unibodies. The '61 is pretty much plain Jane, the '63 however has the large back window with the big chrome, and the rest of the body chrome package. I can supply vins' if req'd for your registry, let me know.
#95
I have a 1963 Unibody lwb 223 manual 3 on tree custom cab in which i am trying to get back running...Just had engine rebuilt,,,installed engine with new clutch...new water pump but cant get gas to carb...did i install the fuel pump wrong...have no manual...i just bolted it on should i have looked at cam or something....so mad...have spent so many hours on the engine area and cant get gas up to carb..the dang thing was running before i took out the engine for a complete rebuild...it did sit for 8 months...dry rot...let me know...want to drive it on labor day...but cant get gas to carb...thanx for any help
#99
robert, still there?
Robert, still looking for unibodies? I have my dad's 62 F250, 3/4 ton "styleside" unibody. It's in "project phase" -- been parked for about 5 years on dad's farm. It has a 6 cyl, 4 spd manual. it's never been modified except for a short block about 7 yrs ago...obviously it was running then, w/ only a few hundred miles on it since the repairs.
Ford says fewer than 6,000 of these were made.
its for sale cheap...in Eastern WI.
contact me... dmanske
#101
on
1961 Merc M-100
I have a 61 merc M 100 LWB, 223 6 cyl, 3 sp OD column shift, bought it in 97 from someone that moved here from alberta. unfortunately it was missing the tail gate because they had a camper on it origionally. & yes i am still looking for a UNI merc gate, I have also thought about selling it because i have to many projects and a few need to go. below is my vin info, I hope its interesting.....
#51532A-5661022NL the breakdown is as follows - (51532 unit) # built in dec 60, (A) gvw 0-5000 lbs, (5) 6 cyl merc truck, (66) pickup body, (10) M -100 series, (22) 122" wb, (N) 1961 model year, (L) left hand drive built in oakville, ont.... ford of canada records show that (quote) there were 3257 of the 1961 mercury light trucks built, all in canada.
#102
#103
on
hay 77 silverstreak
77 silverstreak - i had got my 1961 info from ford of canada, Oakville. that was in may 2000, the contact was and maybe still is? Sandra Notarianni historical consultant. if i remember right she was only there 1 or 2 days a week. but its a point in the right direction, as for the 61 info i posted - the 3257 total was only for 1/2 ton S&LWB, and 3/4 ton LWB models, there could be a breakdown for swb models but she never mentioned it. this ph # is from apr 2000 give it a try, it went to her office (905) 845-2511 ext 1562. good luck on getting the 62 info.
By the way do you know of any merc uni tail gates????
#104
Hey Robert, Please add our collection to your list of unibody owners.
My son and I have four unibodies plus a collection of std trucks.
61 SWB big window
61 SWB small window
61 LWB small window
62 3/4 ton LWB small window
63 F250 4x4
66 F250 4x4
61 to 66 Fords are not o difficult to locate here in Northr California
Warner & Ethan
61 SWB big window
61 SWB small window
61 LWB small window
63 F250 4x4
66 F250 4x4
Warner & Ethan
#105
