Water In Fuel Switch
Originally Posted by edub32
I've never drained the water on mine and the light just came on today . I found the yellow drain switch on the back of the fuel bowl but I wanted to know where it drains to so I could get a jar under there or something.
Thanks in advance.
Thanks in advance.
to see the copper tube. I forget the tube size(for attaching hose), maybe 1/4".
Nut
Well I draineed the switch the first time and apparently I must have a leak in this copper drain pipe because it looked like the bowl drained everywhere underneath. I then started the truck up and got the WIFL light again so I drained the bowl a second time. This time the light went off and all is well. However I have diesel all over the motor now and I tried wiping up as much as I can. Will this be safe to drive with if I let it evaporate for a couple of hours?
I empty the fuel bowl every oil change and of course every third oil change when I change the filter. You really should be doing this more often. How long has it been since you changed the filter?? I would also not buy fuel from that same source again, it takes about 3/4 of a cup of water to trigger that light.
MxRacer32
02-10-2005 05:53 PM
