Wierd -- A/C and 4x4
Alright guys, this is wierd. I put my truck in 4x4 high today and the air conditioning changed from max A/C at the vents to a/c defrost. What gives? It goes back to blowing through the vents in 2 wheel drive, but as soon as it goes into 4 wheel drive it changes. Changed back and forth several times and each time I got the same response. Any thoughts?
I had the same problem. I think my problem was the hub or hubs leaking.... not the lines going to them.
Changed out the factory auto locking hubs to Warren Premium Manual Hubs.
Plugged the vac lines off. No more problems with the A/c vents defalting to the defrost vents due to a vacuum leak.
Only thing now is that if I anticipate needing the 4x4.... must first get out and lock the hubs..... However.... I now have a 2x4 low range ..... just don't lock the hubs and switch the **** to 4x4 low.
