Change the Trans Oil at 131K?
Consesus would say to change the fluid (as much as possible) and filter (maybe), but not to power flush. The latter might break out loose particles that later clog the tranny.
By detatching the return line from the cooler to the transmission, you can effectively drain 90+ percent of the fluid from this port by using a procedure found elsewehere on this site.
1985f350
12-02-2004 02:44 PM
