Hey guys got a loose gas cap guage indicator came on today. Gas cap tight, whats the usual cause of this?
Was the truck refueled while still running?
The loose gas cap indicator is turned on by the PCM when it determines that a refueling has taken place but is unable to pull a vacuum (part of the EVAP emissions test suite) in the fule tank.
You'll need to see if the PCM has stored any DTCs related to this event in order to properly diagnose the fault indicator.
