The loose toilet flange bolt and JeffH
I had linoleum installed in my bathroom earlier this week and today I discovered that one of the toilet flange bolts is completely loose, i.e. as I tried to tighten it the durn thing pulled out completely. Is it possible to get it back in place without removing the toilet or do I have to bite the bullet? The toilet isn't wobbly at all but I suppose I oughta take care of it before I forget about it...
I would pull up the toliet and reinstall with new wax ring and flange, you dont want it leaking all over the place, you would have a real mess. very easy...it will take you longer to get the water out of the tank than repairing the toliet.
and make sure you get all the old wax ring cleaned off
Good Luck
Get a set of bowl bolts that screw into the floor. You put on the cap nut and thread the wood screw portion into the floor.
If the floor is too far gone for that (hole reamed out) get a short 1/4" or larger lag bolt and a washer and screw the bowl down. I have done this many times on floors that were soft, or if the flange was broken.
A galvanized bolt and washer will not rust.
Jeffh, Stephen Colbert would be very upset to see your avatar. Don't you know the countless hours he has put in to warn the public about bears?!?! "These Godless, soulless killing machines..." As an avid watcher of the Colbert Report I can tell you hardly a weeks goes by that bears, in some form or fashion, do not appear on the "Threat Down"...beware the choices you make in life, sir, you reap what you sow.
