speedometer gear
Guest
Posts: n/a
speedometer gear
There are many different gears that were used and it all depends on the year and model of your truck as well as whether or not it still has its original components, such as rear axle, transmission and tire size. The wrong gear will result in your speedometer reporting the rate of travel incorrectly. If you post more data maybe I or someone else might be able to determine the correct part no. for you.
Stock Man
1967 Galaxie 500 convertible (I need factory rims)
1967 F-250 FE 390 4wd
<a href="http://www.hometown.aol.com/tbeeee">http://www.hometown.aol.com/tbeeee</a>
Stock Man
wyazel1
37
08-22-2008 06:16 PM
