V10 timing
The more even intake pulses result in a much flatter torque curve.
Fact: The 5.4L V8 now has VVT (variable valve timing) and 3 valves to get the flattest torque curve possible (80% of peak torque at 1000RPM).
The V10, even 2000-2004 2-valvers, put out 80% of their peak torque at 1000RPM without VVT, 3 valves, or anything else.
(The three-valve V10 is even more of a torque monster, but STILL does NOT use VVT! There's a reason that it doesn't need it - the smooth intake vacuum).
To me, those facts point towards the intake vacuum being smoother, resulting in better low-end torque.
Cool! Thanks! I have no muffler, just the cat and pipe, done by the oriignal owner. I didn't understand the references to "ricer"
Mostly, when I hit it off the line, I lke the tone, but yesterday I punched it once, then REALLY punched it and I heard the high pitched tones people speak of. Kinda yukky sounding, but I have all kinds of power with just the first punch, probably because of the 4.3. All that to say, I can stay away from the high pitched tone and blow most people's doors off, off the line. If I really need it, it is always there.
On a side note, I have had two puny little cars cut me off, I dealt with them severely. They will not mess with any more F350 SD Dually's methinks.
It was nothing illegal or hurtful, other than pride.
