headers
on
Originally Posted by JoeVB
They SHOULD. The block is the same, it is the heads and the pistons that are different between the 302 and 351.
They'll bolt up to the heads, but how they clear everything else in the chassis depends on the particular set of headers. The 351w has a taller deck height, and thus, is both taller and wider. Your headers will be further up (toward the hood), and out (toward the fender). Not a lot, but enough to potentially make a difference.
