What does everyone do when they first buy a pre-owned car?
I just joined this board and I've already solved a couple of minor problems with a new truck (like the dash lights). Thanks everyone for all the great information you post.
I'm curious about what other people do when they first buy a used 4x4 with no service records (mine was from an auction). My general opinion is change the oil, filters, and transfluid and then check over the brakes to make sure they are all up to scratch. What does everone else do?
Steve and Preppypyro pretty much got what I do covered. All fluids are a must as well as all moving joints and suspension componets. I also pull a spark plug or two to inspect as well as plug wires and replace as needed. New thermostat comes with radiator flush as soon as possible if not done with the rest of the fluids. Tire pressure is one that is done first gas station I find where I will also fill the tank.
I've had -many- used vehicles (some only runners until the right car/truck happened along), and was a mechanic through college.
If a vehicle is a keeper, and over 80k miles (many were):
- All fluids and filters (except air, if it was already clean - pretty easy to tell)
- Plugs, wires (OEM spark plug wires aren't great, and generally 'leak')
- shocks / struts
- sway bar bushings and end-link bushings changed for polyurethane
And things I like to change if I get around to it:
- ceramic brake pads up front (burn them in correctly though)
- wheel bearings (changed if putting new rotors on)
- headlights get dimmer as they age. General Electric halogens are brighter than most brands out there, so I'll put them in.
- Original windsheilds on used vehicles are tough to drive with at night, as they have too many pock-marks from debris, causing uneeded glare at night
- shocks / struts
OK, that's quite the list! As a matter of curiosity, I dropped by Lube-X just to get an idea of what they would charge to do *all* the fluids and filters. Their quote was $764 (Canadian). Ouch! Naturally, I want to do it myself, but is there anything that you would get someone with all the good tools to do? Motor, brakes, air and fuel filters, pulgs and leads, and radiator are easy enough, but is it worth getting someone else to do the diff's, tranny, power steering and t-case? Do they all require specialist tools that just aren't worth buying unless you're a mechanic (which I'm not)?
If you're talking about actually rebuilding all of those items you're asking about, you sure bought a lemon truck!
Originally Posted by GammaDriver
If you're talking fluids, no, no special tools are needed.
I'm only talking about changing the fluids. The bloke at Lube-X told me that you need to suck all the fluid out of the diff's because they don't have a drain plug. That seemed surprising to me, but this is the first Ford truck I've had, and I haven't got an repair manual yet. Is he telling me the truth or pulling some dodgy mechanic stuff? He also quoted me $100 (on top of the $120 for the actual fluid change) just to do the transmission filter "'coz you gotta change the gasket and stuff". Seems kinda high to me - but that's why I own a socket set!
your friendly mechanic dont know squat. the rear differential has a cover that is removed (about a dozen bolts) and you clean in out and reinstall then refill, just like any truck made in teh last 100 years. i get confused on the 150 and Explorer we have, but i think the front axle has a fill and a drain plug. drain and blow it out, then refill with new gear lube. the rear is supposed to be synthetic so it is expensive if you follow that rule.-------- the transmission is not tough, just remove the 12-16 bolts and drop the pan. clean out the crud, clean the magnet, and replace the filter inside. the gasket is made of rubber and is reused. if you do this it takes 5 quarts of Mercon V at $5 each so not cheap. If you take off the cooler lines and pump out all the fluid it will take 12-13 quarts. I just did the pan, filter, and cleaned the crud plus 5 quarts.
I can tell you what i didnt do, i checked everything but the cv joints. I just bought my 1st 4x4 and knew i needed tires, no big deal just cost me $800 but now i need a new front half shaft which is around$120 and they want almost $400 for labor, hell with that i'll do it myself. other than that all the obvious like everyone has mentioned. I also have a habit of looking at the brake pedal for heavy wearing from excessive stopping and goings...just one of my things though.
