fluid change or trans doc?
Old Jul 9, 2006 | 12:22 AM
aklim's Avatar
aklim
Originally Posted by cangim
Yes and no, if he is having the transmission rebuilt then they can install during the rebuild process, which is required. If all he is doing is a generic shift kit then yes the BTS VB would be almost a simple plug and play. Brian uses Transgo products in his rebuilds, figure if both Brian and suncoast use their products in some form or another, they have to be doing something right.
Yes but I believe BTS modifies it somehow. I know that it comes with a seperator plate between the VB and the transmission. Which explains why he doesn;t include instructions. So you have to call him when it is installed and youre unhappy.
Old Jul 9, 2006 | 03:57 PM
cangim's Avatar
cangim
Yeah, I know BTS does some fenominal stuff with them, I just know that he uses some of the transgo items. They are in the business and have done the research to know what parts from what vendor will work great together to have the desired outcome. If I could afford one from BTS, I'd have a full on BTS transmission in my truck as well.
Old Jul 9, 2006 | 04:29 PM
aklim's Avatar
aklim
In the VB package he sends you, the plate is Transgo. However, he does tell you what you can do if you want to make it shift harder.
62star
Jul 5, 2012 08:40 PM
ItsAFord55
Aug 6, 2011 11:50 PM
aircargoo
Nov 10, 2009 10:00 AM
Headviking
Sep 17, 2009 06:56 AM
crazer42
Mar 26, 2009 03:54 PM
