Frame work started
Old Jun 28, 2006 | 12:05 PM
Chachi568's Avatar
Chachi568
Frame work started
Just starting to remove the old stuff on my 49 so I can install a MII and was wondering if anyone has any ideas on how to remove the rivets, I don't have a cutting torch so if someone has a tip using normal hand tools that would be greatly appreciated!
Take er easy
Old Jun 28, 2006 | 12:20 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Take an angle grinder with a cut off wheel in it, make a couple of crosscuts in the rivet head, smack it with a hammer and chisel to knock of the scored pieces. then you can take a hammer and punch and knock out the body of the rivet. You could also grind a small flat spot on the rivet head, use a center punch to mark it and then drill it out.
Good luck with it, its loud and dirty work
Bobby
Old Jun 28, 2006 | 12:22 PM
LEckart's Avatar
LEckart
You can use an air chisel or if you don't have a compressor you can use a grinder, either a die type air or electric. Just grind down the rivet head flush and punch out.
Old Jun 28, 2006 | 02:20 PM
AXracer's Avatar
AXracer
If you don't have one, a 4" angle grinder can be purchased for <40.00, and is worth every penny! buy a handful of 1/16" cutoff disks and a 1/4" thick grinding wheel as well as a couple grits of flap disks when you buy the unit. Keep it handy you'll be reaching for it constantly for cutting grinding and sanding tasks. I use mine so much I bought a second one so I could keep a cutoff wheel on one and a flap disk on the other so I wouldn't have to swap disks so often. I buy my cutoff disks and flap wheels online they are much cheaper that way (you'll go thru a lot of them). I use http://stores.ebay.com/Lehigh-Valley-Abrasives for mine.
Old Jun 28, 2006 | 03:14 PM
WillyB's Avatar
WillyB
Originally Posted by AXracer
a 4" angle grinder can be purchased for <40.00, and is worth every penny! buy a handful of 1/16" cutoff disks and a 1/4" thick grinding wheel as well as a couple grits of flap disks when you buy the unit. .
Harbor Freight has them on sale for around $16 - I bought one to try, and it worked as good or better as my older Sears unit does. I have bought two more since, giving me 4 grinders and I keep a different head on each, including one with a cup wire brush.
The Sears unit is used the least!
You do have to be careful - I see that HF has two different models, with the cheaper one about $1.00 less. The more expensive one has more power and will fit a 4 1/2 inch head - well worth the extra $1.
Please take the money you save and buy a full face mask for protection - I also wear a hat to keep the filings out of my hair too.
Old Jun 28, 2006 | 04:40 PM
AXracer's Avatar
AXracer
I wear a full face shield, the cutoff wheels have a nasty habit of flying apart when you bind them up.
Old Jun 28, 2006 | 05:57 PM
Code3's Avatar
Code3
Make sure you use a good punch too; Craftsman or equivalent. Hold it in place with a set of vise-grips and whack it with a 5 lb sledge.
Old Jun 28, 2006 | 06:01 PM
WillyB's Avatar
WillyB
Talking
What, no guts?
Old Jun 28, 2006 | 07:05 PM
Randy Jack's Avatar
Randy Jack
Ditto on the HF 4 1/2" angle grinders. I also have four of them, each with a different setup on it (cutoff wheel, flapper disk, grind stone, cup brush).
HF also sells an inexpensive air hammer that works really well. Saves a lot of scraped knuckles and smashed fingers. It comes with the punches and chisels you'll need for those pesky rivets. Replace them with grade 8 bolts when you reassemble.
Old Jun 28, 2006 | 07:59 PM
Code3's Avatar
Code3
Smile
Originally Posted by WillyB
What, no guts?
Plenty of guts..and broken fingers! I have too many stitches from working on these #%^?@! jets...not trying to kill myself with a truck!
Old Jun 28, 2006 | 09:14 PM
havi's Avatar
havi
I'll have the Roast Duck
with a backing pad, 24 grit open coat sanding discs(SAIT is the brand we use) make quick work of any metal in its path. Compared to a hard wheel they leave less of a gouge. We all use hitachi electric grinders at work. They weigh a little less than most others, and last a long time. And like Ax said, buy in bulk...lots cheaper.(box of 25 for $20)
Old Jun 28, 2006 | 10:43 PM
Chachi568's Avatar
Chachi568
Thanks for all the replies, ground the heads off and used an air chisel to shoot the rivets across the shop. I did find out that a 3lb hammer can make blood shoot out from under your fingernail. Rookies always do things the hard way!
Take er easy
Old Jun 28, 2006 | 10:51 PM
kcb37's Avatar
kcb37
I wish I could count how many time I have hit my own hand with a hammer. Oh well.
At least now it dosen't hurt as much. LOL
Old Jun 28, 2006 | 11:05 PM
Code3's Avatar
Code3
Vice grips! See *****?! Look what you made him do!
Old Jun 29, 2006 | 12:03 AM
WillyB's Avatar
WillyB
That is a newbie mistake . . . everybody knows from before kindergarten that that Curly holds the punch while Moe swings the hammer!
