Clutch plate ?
Old Jun 23, 2006 | 06:58 AM
cujo8's Avatar
cujo8
Clutch plate ?
During a std tranny rebuild due you need to replace both the friction clutch plates and the steel clutch plates? How many friction and steel clutch plates are needed for 77 C4 AT rebuild?
Thanks.
Old Jun 23, 2006 | 07:19 AM
Clubwagon's Avatar
Clubwagon
Can't say how many clutch plates there are in a C4 but you only need to replace the steel plates if they are heat checked (same as resurfacing a flywheel when replacing the clutch) or if they are damaged from the burnt clutchs being worn down to the steel.
You should always replace the clutch plates when rebuilding an automatic unless the original plates look like new.
Steve
'95 Clubwagon XLT
Old Jun 23, 2006 | 07:54 AM
stuart1's Avatar
stuart1
If you order the proper kit everything is included.
Old Jun 23, 2006 | 08:24 AM
Clubwagon's Avatar
Clubwagon
A "master overhaul kit" includes the clutches and steels. A plain "overhaul kit" includes the clutches but not the steels.
Some kit manufacturers use their own unique names so you do need to check.
Steve
'95 Clubwagon XLT
Old Jun 23, 2006 | 08:50 AM
stuart1's Avatar
stuart1
I said proper kit.
Old Jun 23, 2006 | 03:56 PM
cujo8's Avatar
cujo8
I found a reference that says there are 5/5 friction/steels in the front clutch pack and 4/4 friction/steels in the reverse clutch pack. I will just go ahead and get them all just to be complete. Thanks for the input.
Jim
Old Jun 23, 2006 | 04:03 PM
Clubwagon's Avatar
Clubwagon
I said proper kit.
I was just helping him understand what the different types of kits were and how to identify them.
Steve
'95 Clubwagon XLT
Old Jun 23, 2006 | 04:27 PM
stuart1's Avatar
stuart1
Jim
The rear pack will have 1 more friction than steels.
