2000 Mustang GT heads on 99 Expy 5.4L
Thanks for the input--I know the 2000 4.6L that the heads came off of are Romeo engines--would one expect that these heads would fix the dreaded oil leak problem-or put a different way, since the problem seems to be with the heads rather than the 5.4L blocks, is it safe to assume that this is a safe path to follow to not have a repeat leaker? While its apart, anything else I should look at--I'll be putting new plugs, hoses tensioners and chain guides. Should I also replace the head bolts, as I believe they are torque to yield?
Reading through the Ford Racing Performance Parts website says the heads are Romeo design PIs... Romeos use a rocker girdle, where the Windsors do not. Windsors use another strengthening design.
Somebody has mentioned valve lash adjustments are slightly more difficult with the Romeo's rocker girdles.
-Kerry
-Kerry
So then these bad boys will work? http://www.avengercylinderheads.com/...products_id=67
But these are more in my price range.
http://www.avengercylinderheads.com/...products_id=66
Interesting - Makes me wonder why Ford doesn't market the heads as a direct replacement for all PI equipped vehicles? They list them as a GT only item - is there any other thing, besides being Romeo castings, that make them identified as a Mustang only part? If not, then I can't understand the logic.
-Kerry
-Kerry
I don't know, the magazine checked the cam lobe measurments and the were the same as the heads off of the GT. Same lift and duration. The 5.4L was out of a 2000 Van. Looking them up online, Windsors and Romeo's show different cam shafts .
CAMSHAFT, Expedition, Navigator, 4.6L, Romeo, Right - 4.6L, 5.4L - 4.6L, 5.4L 97-99 $324.64
CAMSHAFT, Expedition, Navigator, 4.6L, Romeo, Left - 4.6L, 5.4L - 4.6L, 5.4L 97-99 $324.64
CAMSHAFT, Expedition, Navigator, 4.6L, Windsor, Right - 4.6L, 5.4L - 4.6L, 5.4L 97-02 $184.82
CAMSHAFT, Expedition, Navigator, 4.6L, Windsor, Left - 4.6L, 5.4L - 4.6L, 5.4L 97-02 $132.71
Not sure why, but they show the same cams in PI and non-PI heads.
I guess the cams are different. Why is the right side head more than the left????
The Mustang cams show 99-2000. Very strange.
I was looking thru the Ford Racing catalog http://www.fordracingparts.com/downl...gs/2006-pp.pdf And found no cam listings for these engines and just a couple of cylinder heads.
Now I'm all confused
