no spark
Old Jun 21, 2006 | 08:00 AM
sledderxc's Avatar
sledderxc
Unhappy no spark
1986 f-150, 300 ci 1 bbl; stored truck last fall. fogged out engine, pulled battery etc etc. this spring, attempted to start it and no spark. engine turns over, getting fuel, distributor is turning but no spark at the plugs. changed the tfi module on the distributor and still no spark. looking for suggestions or trouble shooting sequence to get the old girl running. getting current to the coil, but not sure how to check if getting current to the distributor.
Old Jun 22, 2006 | 06:13 AM
sledderxc's Avatar
sledderxc
replaced coil yesterday; same results no spark. will attempt to trace down wires today looking for a break or bad ground. any other suggestions would be helpfull
Old Jun 22, 2006 | 08:09 AM
big hoss 29's Avatar
big hoss 29
Small furry creatures love to chew on wires and leave you scratching your head. Another thing it could be is the pick-up coil inside the distributor could be bad. Pull the distributor and have it tested at a parts store to see if it's ok.
Old Jun 23, 2006 | 06:27 AM
sledderxc's Avatar
sledderxc
no luck finding any wiring break or bad ground. going to pull distributor today and have it checked out. if this fail; maybe go to a junkyard and convert this tfi system to the old duraspark ii
JimiLL
15
Dec 9, 2014 12:02 PM
ewhit8
Jul 20, 2014 01:53 PM
THAT.GUY
19
Jan 12, 2013 03:00 PM
Mudman
Oct 11, 2010 07:11 PM
WaywardMIG3510
Electrical Systems/Wiring
15
May 26, 2003 06:19 PM
