a/c quits cooling
Welcome. first dont shut her off anymore. Leave her run and see if the clutch engages. What happens is the magnetic field may get weak and wont pull it down. To fix this you need to pull the bolt out of the middle and remove a shim. This will bring the clutch ring closer to the ac pulley and allow engagement. Ive done it twice in 430k miles.
Replace your orifice tube, takes 3 minutes and $3.00. It may cost you a little more to recharge the system.
I had a similar problem. Fluxuating pressures, clutch kicking in and out whenever it wanted to. I discharged the system and pulled the orifice tube. There was a little bit of metal shaving at the larger end. I have been assured that although the metal shavings are normal, it only takes a very little to start reducing flow. So I replaced it, recharged it and all is great.
If you have gauges and a tank of 134A here's some stuff.
Low side should read 35-41 psi @ Idle
High side should read 195-201 @ Idle
Low @ 2000 rpm 30-32
High @ 2000 rpm 200-225
These readings are best taken at 72 degrees. If it is warmer out, or humid the readings will be slightly higher.
After discharge, remove black clip from tube coming out of firewall next to the canister.
You will need the proper tool to unseat the clip within the tube - AC Orifice tube removal tool, same as the fuel line disconnect tool.
Pull the orifice tube out with needle nose pliers and inspect for debris. Put the new one in RED SIDE toward the cab. Reconnect the tubes, install clip and recharge.
We thought it was electrical, low/high charge, clutch, switches...the whole shabang. Then the quiet guy mentioned something about an orifice tube. This dude needs to speak up more, he could save us some cash.
I have to ask: I have a 2002 as well, F-350 Lariat
My truck the other week or so, I was using the A/C on the MAX COOL setting, and the A/C just stopped, fan was blowing, but no air or anything, then it just came back, happened for about a minute or so
any ideas? it was on May 27th, just under 1 month, hasn't happened again, yet
Check with your local dealer.... there was a TSB (technical service bulletin) published for this exact issue. There is air in your refrigerant system and they will evacuate it and recharge your A/C system. If I can find it I will post the TSB bulletin #. If I remember correctly the 02-03 production years were effected.
