Rear Seal?
Old Jun 17, 2006 | 01:25 PM
benton's Avatar
benton
Rear Seal?
I've got an oil leak that seams to be coming from the back of the oil pan (near tranny) on my '88' 4.9 6cyl.. I thought maybe it was the oil pan gasket, everyone I talk to has said it's probably the crank seal. I don't know if this is something I want to mess with or not. I'm not ignorant but this sounds like it could be a tough job and everyone says it's easy to screw up. I have the tranny out right now, don't think that will help me though. Any input would help. What would be a good manual for this job (might make the decision to do it myself easier). I've had three freinds tell me three different ways to do it! ...... HELP
Old Jun 17, 2006 | 06:02 PM
offroadguy's Avatar
offroadguy
i changed my rear crank seal and it was pretty simple. i have a 91 and i'm not sure if it is the same seal design. mine was a 1 piece seal. i just took an oring pick and pulled it out and took some crisco (baking grease) and lubed the seal up and put it back in with a dead blow hammer and had no leaks
Old Jun 18, 2006 | 11:36 PM
the peppermint's Avatar
the peppermint
did the same on mine, oil pan will come off without lifting the engine, its not that bad
Old Jun 18, 2006 | 11:48 PM
benton's Avatar
benton
thanks guys. I read up on it and I think I can handle it. I'm at least going to give it a try.
Old Jun 19, 2006 | 06:30 AM
kotzy's Avatar
kotzy
Make sure you put some sealeron the flywheel/driveplate bolts, they are bored
thru the end of the crank and they will leak oil.
Old Jun 19, 2006 | 12:57 PM
benton's Avatar
benton
what kind of sealer?
Old Jun 19, 2006 | 05:59 PM
kotzy's Avatar
kotzy
I use aviaton permatex #3 (the brush on stuff) i would guess the #2 would do
as well just don't overload the bolt.
Old Jun 20, 2006 | 10:21 AM
felixr's Avatar
felixr
im sorry, did i read correctly . . . our 4.9 doesnt require the engine to be lifted to remove the oil pan?
Old Jun 20, 2006 | 12:16 PM
kotzy's Avatar
kotzy
to replace the seal the pan doesn't have to come off pull transmission and flywheel
and the one piece seal is loooking at you.
Old Jun 20, 2006 | 01:27 PM
andym's Avatar
andym
You read correctly, but the information is wrong. The oil pan will not come off without lifting the engine.
Old Jun 20, 2006 | 02:10 PM
felixr's Avatar
felixr
thats what i always thought. damnit, i got all excited lol
Old Jun 20, 2006 | 11:46 PM
benton's Avatar
benton
All right well which is it? I already have the tranny out. I don't really have the stuff required to lift the engine but, might be able to get it. Probably a little over my head at that time. It is a 4x4. Think that might make a difference.
Old Jun 21, 2006 | 07:35 PM
offroadguy's Avatar
offroadguy
The oil pan does not need to be removed to change the rear seal. If the transmission is out the engine wouldn't need to be lifted to get the pan out anyway. Just use an o ring pick and pull the seal out. put some crisco on the new seal and tap it in with a deadblow.
