Pertronix plunge
Old Sep 12, 2001 | 12:07 AM
jon69f250's Avatar
jon69f250
Pertronix plunge
I ordered an Ignitor, coil, and wires today.
For those of you who have been following my great ignition adventure, I recently ripped out a non-functioning computer system from my otherwise stock '69 360 and replaced the spark plugs. In the process, I cracked the distributor cap so now that is new too (NAPA Part. Ford apparently doesn't make them anymore).
The bottom line is that, assuming I can get the Pertronix installed right, I should have a pretty much brand new ignition on the truck.
I'll keep everyone posted on the installation and results.
Old Sep 12, 2001 | 09:54 AM
jbhf250's Avatar
jbhf250
Pertronix plunge
There is a `black` grounding wire that goes from the advance plate to the base INSIDE the dist....You must keep that connected when you bolt in the module! The instructions may not be that clear ...Just for info only!
__JOHN__Õ¿ö
FTE Club #7
Member-
http://www.cruisin-north.com/
Santa Rosa, Calif.
72 F-250
ICQ#6030753
http://www.ford-trucks.net/users/jbhf250/
https://www.ford-trucks.com/pictorial/big/1972_f250_2.html
Old Sep 12, 2001 | 05:06 PM
greghoffmann's Avatar
greghoffmann
Pertronix plunge
Did the same thing to my '71. Piece of cake installation.
1971 F-350 1 ton dump, ground up fully restored w/ 360 motor
Old Sep 16, 2001 | 05:33 AM
79Moon's Avatar
79Moon
Pertronix plunge
Old Sep 16, 2001 | 01:12 PM
mrgoodwrench's Avatar
mrgoodwrench
Pertronix plunge
I've been consigering a Petronix ignition too, do they make a unit that will work with my Duraspark distributer?. The durasparks been giving me alot of headaches lately, and would like something a little simpler. how does the petronix perform compared to stock ig nition?
FordHarleyTexas
26
Dec 29, 2011 08:18 AM
desoto dave
May 7, 2009 11:58 AM
johninraleigh
Electrical Systems/Wiring
Oct 17, 2007 10:01 AM
JLb300
Jul 7, 2004 08:23 PM
mar9999
Jan 26, 2004 06:43 PM
