Which Rear is this?
Jun 16, 2006 | 02:02 AM
Which Rear is this?
2001 v10 with unknown rear end. No vehicle certification label on the door.
Rear end has two steel tags that are hard to read but appear to say:
S 141 H
73 105 OK30
----------------and the other says
SW140 SYNTH
OIL ONLY
The tach reads about 1900 rmp at 60 mph, but it's not the most precise dial.
Jun 16, 2006 | 06:27 AM
What truck is it f250 350 450
Jun 16, 2006 | 06:29 AM
Single or Dual Rear Wheels?
Single Rear Wheels - It's a Ford 10.5 Rear
Dual Rears - It's a Dana 80
Jun 16, 2006 | 10:48 AM
It's an F-250 v10 SD CC-LB SRW XLT 4x4
Gotta love the alphabet soup.
Trying to figure if it has 4.1 or 4.3 rear gears. Thanks
Jun 16, 2006 | 11:22 AM
Check post #3 in this link, but from the RPM's you're talking about, I would say you have 3.73's.
4.10's will run around 2100-2150, 4.30's will turn 2350 - 2400 at that speed.
Jun 16, 2006 | 11:48 AM
pm me with a vin number and i'll look it up.
Ed
Jun 16, 2006 | 01:01 PM
Check your VIN door sticker for the code under Axle. Here is the link for future reference:
https://www.ford-trucks.com/forums/s...d.php?t=139080
A heck...here are the codes...
Axle Type
31 — 3.73 non-limited slip, F-250/Excursion
C1 — 3.73 limited slip, F-250/Excursion
32 — 4.10 non-limited slip, F-250
C2 — 4.10 limited slip, F-250/Excursion
33 — 4.30 non-limited slip, F-250
C3 — 4.30 limited slip, F-250/Excursion
biz
_______________________________
2003 F250 SD SC 142" XLT FX4
V10 Auto 4x4 3.73s
Jun 16, 2006 | 01:20 PM
That's almost the exact same thing my diff tag says (it's in my hand)...
My says "L73" instead of just 73. Here's why:
I have a 3.73 limited-slip. So, there should be a "3L73" on my tag. But the first "3" was under the bolt head and was crushed, so it's almost impossible to see. The "L" means limited-slip.
On yours, the tag means it's GOT to be a 3.73 with an open diff.
